Author Topic: 550's...and sooty plugs...  (Read 814 times)
Offline Lumbee
    • My pics...
« on: June 16, 2007, 07:54:25 PM »
...got a 74 550 I've been bringing back from the dead the last few months.  Did all the regualar maintanance stuff...set vavles, timing, cleaned carbs.  What I have now is serious plug fouling.  I am running pods, but no matter what the jetting the plugs are sooty.  I have 100 jets in it now, and still fouling.  The spark and electrical is strong, so I don't think thats the culpret.  Any ideas???
"I'm not a welder, but I play one on HondaChopper.com"
Stevien1
Re: 550's...and sooty plugs...
« Reply #1 on: June 16, 2007, 08:31:40 PM »
Do you have near battery voltage (within .5v) at the black/white wire to the coils?  I went through something similar on my 550, ran through the carbs half dozen times adjusting everything one step at time.  I found that my bike was loosing almost 1.5v to the coils, so after some wiring work, no more fouled plugs!
You've re-checked the float heights, needle clip positions, and air screw adjustmensts- right?  ;)
Offline Lumbee
    • My pics...
« Reply #2 on: June 17, 2007, 07:03:44 AM »
...good tip, I'll check that out.  Although I used one of those spark test dealies to check spark at the plugs and it looked pretty good...
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #3 on: June 17, 2007, 10:48:06 AM »
I had the same problem on my 500, running with pods and 4-1 exhaust.
By any logic it should have been lean, but it fouled plugs badly with soot.
Short story is I hadn't cleaned the emulsion tubes when I rebuilt the carbs.
When I did remove the tubes they were completely caked with
gunk. Cleaned 'em up and the problem went away!
Bikes parked out front mean good chicken-fried steak inside.
