Author Topic: Homemade Manometer  (Read 88224 times)
Offline OldSchool_IsCool
  • Really feeling like an
Re: Homemade Manometer
« Reply #125 on: March 03, 2009, 07:30:03 PM »
The trouble with that idea is changing one carb affects the others.  You really need to see the pull from all four at the same time.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline tlbranth
« Reply #126 on: March 03, 2009, 08:47:18 PM »
I made this mercury manometer back in the early 70's. There was an article in Cycle World or some such. Each column is actually a U-tube bent using a propane torch. The hose is surgical tubing. I made my adapters by drilling holes longways through the appropriate bolts (actually my dad did it at the sheet metal shop where he worked) and screwing the bolts part-way into some 1/4" copper tubing. I put a nut and o-ring on each bolt to seat it to the carb. The surgical tubing then slips over the copper tube. I just resurrected the thing to tune my bike which hasn't run in many years.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline mark
« Reply #127 on: March 03, 2009, 09:18:50 PM »
That looks like art. You could tune a Rolls with that setup.
Now a question.....
Are the u-tubes connected down inside there somehow?
F you mark...... F you.
Offline tlbranth
« Reply #128 on: March 04, 2009, 08:02:57 AM »
Mark, Yes the tubes are held down with wire through vertical wood supports which are perpendicular to the front panel and twisted to hold tight.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline UnCrash
  • Pass
    • My Blog
« Reply #129 on: May 16, 2009, 07:32:18 PM »
And having said all that, let me tell you - I tried both. That is, I borrowed a manometer-set one, and i made myself one with the tubes. The tube one is MUCH MORE sensitive and accurate. No problems with damping, and satisfaction of making it by myself - priceless....   It came to the stage where tightening of the locking nut would affect the setting. It's that sensitive.
In looking at this setup I wonder why you wouldn't terminate all  4 hoses into a single container...  I guess the long hoses all joined together at the bottom works the same...
I'm thinking of rolling one up tomorrow.
Yes, for me $80 for a Morgan is a great sounding deal, but with all the other odds n ends I need it isn't in the budget.
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« Reply #130 on: May 17, 2009, 07:23:30 AM »
hey ben,
if you build one with hoses that terminate into a shared reservoir make sure its airtight. I made one that way and could never get it to seal, so it would suck the oil up the tubes into the carbs.
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline UnCrash
  • Pass
    • My Blog
« Reply #131 on: May 20, 2009, 08:10:36 PM »
I received my Carb manifold adapters from Z1 today and headed out to the shop to finish up my home made manometer / vacuum gauge.
I build it based on a design shown earlier in this thread by Tower using 1/4" tubing, and a couple outdoor plant watering kits from Lowes for all the connectors.  Lowes even has on/off valves for the watering system which I used as restrictors.
It took a while to dial in the restrictors in evenly. I filled the tubing with a gas/2stroke oil mix for my weedwacker.  Finally everything settled down on me and I could synch the carbs.  Now the tool is dialed in and so are my carbs.  Smooth idle at 1100 and will idle down to 900 if I let it.
The ZI adapters were $15 including shipping, and the tubing and assorted other parts were about $10.  Here's what I ended up with.
« Reply #132 on: January 17, 2010, 06:06:54 PM »
Most people use ATF. This is a real old thread. For a $100.00 and if you have a lot of bikes,lots of friends,or plan on riding for a lot of years this is not a bad investment.Good tools last your lifetime ;)
« Reply #133 on: June 27, 2011, 10:37:18 PM »
got my homemade manometer finished the other day...check the photos...tubing from Lowes...vacuum t fittings from autozone... 5mm carb fittings from Z1 Enterprises, used 145 main jets for restrictors...(yes you will need restrictors, I thought the fittings from Z1 came with restrictors but no, I tried it without but it will quickly suck fluid into engine)  I used two stroke oil for fluid.  Works quite well...very sensitive...and seems accurate...still might modify it to have 4 separate reservoirs...I think this will reduce the sensitivity to a more practical level.   I spent about 20 bucks but had stuff like plywood, zipties, screws and hardware lying around.
« Reply #134 on: June 27, 2011, 10:42:26 PM »
...the carb fittings and detail of how I used main jets for restrictors...
Offline hapakev
  • Your Standard
« Reply #135 on: June 28, 2011, 06:42:17 AM »
how did you get those jets down the tubes like that? long screwdriver?
Smoking Jack
1978 CB750F(ish)
« Reply #136 on: June 28, 2011, 01:21:10 PM »
it's actually a splice in the tube, put the smaller threaded end in the end of one tube, then I used a razor blade to thin the inside of another piece of tubing so it would fit over the fatter part of the jet.
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #137 on: June 28, 2011, 07:15:26 PM »
What are those long fittings you are using?  I know you said you got them from Z1, but I can't find them.  I made mine by using a 5mm die to thread one end of a brass connector but it's pretty short.  I think those long ones would be much easier to use.
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
« Reply #138 on: June 28, 2011, 10:43:17 PM »
yeah, the long length is nice...
http://www.z1enterprises.com/detail.aspx?ID=3263
Offline ksmith0034
« Reply #139 on: June 29, 2011, 03:36:29 AM »
Awesome, thanks.
