Author Topic: Newly rebuilt engine stuck every morning  (Read 1529 times)
nhYeti
« on: June 18, 2007, 03:31:47 PM »
Hi all :)
I just finished rebuilding my '75 gl1000 engine  (companion to my trusty '74 cb750) about 500 miles ago, and have run into an odd problem. Every morning, the engine is stuck and won't crank. I have to either hit the starter button a couple of times, or if its bad, stick in the kick starter and knock the engine loose. This is definitely the engine and not the starter. Once the engine is freed, the bike runs PERFECTLY for the rest of the day. Cranks freely, plenty of power, no odd noises, no overheating, etc etc. When I changed the oil for the first time at 200 miles, no pieces came out, and there was very little magnetic material residue on the oil drain plug. All the bearings (plain and ball) are new, and I plasti-gauged the plain bearings. Rings are new as well. Any ideas what in the world is happening or what I did?
Thanks all,
Jordan
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Newly rebuilt engine stuck every morning
« Reply #1 on: June 18, 2007, 03:49:41 PM »
Something amiss in the starter engagement??
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: June 18, 2007, 04:08:24 PM »
Sounds like a combination of new and tight plain bearings, pistons and rings.  What type of oil are you using?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
nhYeti
« Reply #3 on: June 18, 2007, 05:01:38 PM »
I'm using Rotella T 15w-40 (engine specs 10w-40).
Jordan
Offline 78 k550
« Reply #4 on: June 18, 2007, 08:39:22 PM »
I would say tight engine rebuild.
Go here they will answer all your questions.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline kslrr
« Reply #5 on: June 19, 2007, 08:39:15 AM »
I don't know Rotella.  Is that a mineral oil verses synth?  For engine brake ins, a mineral oil is recommended and you might check with a Honda service shop as to what oil weight they recommend for brake in.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline crazypj
  • I'm brill, me
« Reply #6 on: June 19, 2007, 08:52:51 AM »
 Just a thought,
Are you parking on main stand or side stand?
 You didn't mention if it smokes after starting?
Try main stand and see if there is any difference ( maybe getting slight hydraulic lock on lower cylinders?)
PJ
