Author Topic: Winkers on the blink.  (Read 1789 times)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« on: June 20, 2007, 02:56:33 AM »
My front turn signals are on solid but the rears are working fine. If I run the headlight on highbeam, then the front signals work fine. I've since noticed my lowbeam isn't workings. The wiring looks good. Whats going on?
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Re: Winkers on the blink.
« Reply #1 on: June 20, 2007, 08:23:23 AM »
Possible electrical disturbance in the machine aura.
Either you or the bike has blasphemed against the tron god.
Have you sacrificed a goat at moonrise and placed the entrails on the bike in the form of a pentangle?
What Bike?
What has changed since it left the factory?
Do you have a wire diagram?
 :-X
Offline CBGBs
« Reply #2 on: June 20, 2007, 06:25:14 PM »
Sorry, I didn't think this would be so model specific amongst the SOHCs. :-[
The bike is a 75 400f.
The bike is very stock other than the rear turn sig. wiring that has not the original connectors. I've used butt connectors and electrical tape wrap.
I have a wiring diagram.
Please help. ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: June 20, 2007, 06:48:02 PM »
pull out the headlight and start poking around.  I can't reach from here ;D
Offline 333
  • Time for change
« Reply #4 on: June 20, 2007, 07:41:53 PM »
I can see it from where I am.  It looks like the ground for the headlight and both turn signals are connected to each other, but aren't connected to ground.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 750goes
  • it will live
« Reply #5 on: June 21, 2007, 02:13:34 AM »
great vision 333......... ;)
hope it is the right answer though ??
Offline CBGBs
« Reply #6 on: June 21, 2007, 02:52:24 AM »
I have poked around the bucket. I looked for frayed wiring and bad connection with the turn signal wiring and found no real problems. They work fine with the high beam on. I'll recheck the ground. :)
pyro139
« Reply #7 on: June 21, 2007, 03:21:11 AM »
may be the relay, i also recently replaced my rear lights but my front and rear lights are linked my new rear signals are less power than the relay so they dont flash since thjere linked either do front, seems yours arent link and may be that your new lights are more power than the relay so they sucking all the power leaving no power for other stuff on same circuit witch should be head light other signals and horn, when you switch to high beam it forcing ectra power so every thing work but sucking battery faster, if you still have old lights try conecting them and hold assembly to frame to ground to see if stuff works with factory lights, if it does probaly your relay.
« Reply #8 on: June 21, 2007, 08:54:51 AM »
How do your turn sigs work with the headlight disconnected?
Did this happen suddenly?  Or, was it technician induced by some recent changes?
Offline CBGBs
« Reply #9 on: June 23, 2007, 06:09:40 AM »
I recently replaced all the turn signals, as the bike had none when I took possession of it. I have been riding the bike for only a couple weeks  and I noticed this  during this time. I believe the lowbeam was working.
« Reply #10 on: June 23, 2007, 09:40:58 AM »
The stock front signals on a 75 400F are dual element and each require three connections to operate.  Depending on the side (L or R) you need O, O/W, Green, or B, B/W, Green.
The green connection must be made between bulb socket and the wire harness green wires.  The headlight fork mounts are rubber isolated from the frame ground and are unreliable as a battery negative post connection, whereas the green harness wires are directly intended for that function?
What wires did you use to make the signal connections?
I asked ...
...because it would help me analyze current paths contributing to your malady, and you asked what was going on.
But, I won't be making anymore guesses. ???
Good luck!
Offline CBGBs
« Reply #11 on: June 23, 2007, 01:23:49 PM »
I've removed the Headlight and the winkers worked same. I've been looking at the wiring and schematic and I'm wondering what a Position light is. The front signals are only two wire (o,o+w and lb,lb+w) although the schematic includes a ground, this is non existant. I've disconnected the position light wire and the signals work fine. I guess I was running with parking lights or something. I had the wire colors matched up inside the bucket but no lights came on in the Park pos of the ignition switch. What is the position light for anyway? Why a dual filament bulb up front? Are they suppose to be on in lowbeam?
« Last Edit: June 23, 2007, 01:29:03 PM by CBGBs »
Offline 333
  • Time for change
« Reply #12 on: June 23, 2007, 02:08:30 PM »
The park position of the ign switch iwill only light the tail light.  The idea being that when stopped on the side of the road, the tail light is the one pointed at traffic.  Position Light might be a reference to what I know as marker lights.  If there is no green wires coming from the lights, then there is no ground.
750goes: See?  No ground!  I told you I could see it from here.
Offline 750goes
  • it will live
« Reply #13 on: June 23, 2007, 10:45:40 PM »
333,
you are a true legend................. ;D ;D
from one who can't see whats in front of him
Offline CBGBs
« Reply #14 on: June 24, 2007, 04:28:30 AM »
THanks fellas. It turns out this was not a problem after all. The position light are basically optional. I've got them disconnected now and I feel normal again. Its too bad the headlight is only available from the dealer for $45. Anyone know of a better deal?
Offline Frrrrunkis
  • Southern Fried Pest
« Reply #15 on: June 24, 2007, 09:33:32 AM »
After I painted my new headlight / signal bracket, I had a problem with my turn signals, where they wouldn't work right, turns out, the ground from the wiring harness connects to the nuts inside the headlight that hold it on, the bolts have to make good contact with the metal of the bracket, to pass the ground on to the turn signals. I scraped the paint off behind the washers where they make solid contact with the metal, and that fixed it. Whoever had the bike before me apparently couldn't figure this out, couldn't get the turn signals working after rigging the headlight back on when he wrecked it, and didn't use the original nuts with the ground wires on them. So he cut the turn signals off, bracket and all, and I had to get a whole new assembly off ebay.
I'm just wondering one thing, with the headlight in low beam, the turn signals are on steady, with it on high beam, they are off, bt the blinkers work in both high and low beam. Is it supposed to be that way?
1975 CB400F - "Ol' Red"
Opie & Anthony - Spread the Virus!
my bike pics - http://www.flickr.com/photos/10057704@N05
or http://www.bikepics.com/members/frrrrrrunkis/
If it appears that I don't know what I'm talking about or doing in this post, I more than likely don't
Offline CBGBs
« Reply #16 on: June 24, 2007, 04:48:32 PM »
Yes, they do work that way. It's apparently an option. If you want position lights then connect the wires that have a white stripe. If you don't you'll only be connecting the Light blue and Orange wires. :D
Offline 333
  • Time for change
« Reply #17 on: June 24, 2007, 06:14:51 PM »
It's not an option, someone has put the wrong turnsignals on your bike.  I just checked the Honda Service manual for that bike, and they're there.  We are talking about a US model, aren't we?
« Reply #18 on: June 24, 2007, 07:02:02 PM »
The 400 has a weak charging system and battery.  To conserve power, the front position lights go off when High beam is selected.
As stated before, the front turn signals for the 75 400F have THREE connections for two elements.  The elements share a common 12V return at the bulb socket base.  Blue or Orange powers the blink element and the B/W or O/W powers the position light element.  Neither will work properly unless there is a socket base connection to the green harness bundle.
I don't care if your signals only have two wires to present to your eyes.  If you have dual element bulbs you have three connections to make and ensure they are made.  If you have single element bulbs and sockets in the front mounts, then you put the wrong signals on the bike, and they will either blink or be position lights, but not both.
Do you know what bulb numbers are stamped on the mount base?  Does the bulb base have two nubs on the bottom or one?
Offline CBGBs
« Reply #19 on: June 26, 2007, 02:46:26 PM »
Guys! Thanks but the issue is completely resolved. I have the proper bulbs and the proper signals and the wiring is working properly. There is a ground working the signals but its not part of the signal unit. That is if you removed the signals from the bike there would be not green wire attached because those are in the bucket.
   When I said "option" , I meant "optoinal". As in, "It's optional to connect the position lights."
Thank you :)
