Author Topic: Lever Redux  (Read 3359 times)
Offline Bob Wessner
  • "Carbs Suck!"
Lever Redux
« on: June 20, 2007, 02:36:21 PM »
I don't know about anyone else, but I eventually got tired of looking down at my yellowed, cracked and peeling levers. Last year some time, a member mentioned that Plasti-dip came in clear as well as colors. I had some black around, I had used it for some tool handles. I picked-up some clear and thought I would give it a try this past winter. I slit the old covering and peeled it off. Polished the levers then wiped them with some acetone. It seems to work pretty well and is holding up nicely. At least they look presentable until I happen upon an NOS pair. ;)
A couple of tips, if you are going to use black as a substitute for the end caps, do the black first. Doing the clear, then the black, leaves a feathered look between the two. Thin the clear (you can thin upto 10-20%) and submerge and withdraw slowly to avoid any bubbles. The directions say you can recoat within 30 minutes, but I found if you do multiple coats (I used three to get what I thought would be a more durable cover) I would wait a day or two, otherwise you get some small bubbles that I think are being caused by out-gassing of the solvent from layers below.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Lever Redux
« Reply #1 on: June 20, 2007, 02:49:25 PM »
Nicely done, Bob. Good tip.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Raul CB750K1
Re: Lever Redux
« Reply #2 on: June 20, 2007, 11:53:08 PM »
I actually like the yellow, patinae-looking old levers. Mine are yellow but I like them that way.
I have always wondered what was it for. I guess to prevent the gloves getting dirty by the aluminium oxide.
The rubber caps are available from Honda.
kaybee
Re: Lever Redux
« Reply #3 on: June 21, 2007, 08:15:54 PM »
Excellent idea especially if you have replaced one of the levers as I have. I'll them both and have a matching set!
 Thanks for the tip...
Al_Aaraaf
Re: Lever Redux
« Reply #4 on: July 06, 2007, 01:14:17 PM »
My assumption was that it was keep the lever from chilling an ungloved hand. After replacing one of the original levers I noticed a significant difference in the perceived temperature of the coated lever versus the uncoated one.
Re: Lever Redux
« Reply #5 on: July 11, 2007, 06:10:39 AM »
Nice work Bob. I just peeled the yellow junk off and polished the levers. I may go back and coat them as you did.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Lever Redux
« Reply #6 on: July 11, 2007, 08:46:40 AM »
I know what you mean. Mine were yellow, split, cracked and had pieces missing. This was a great improvement and seems to be holding up very well.
