Author Topic: Removing CB550 rocker arms  (Read 2611 times)
newcomtd
« on: June 20, 2007, 07:15:46 PM »
How do you remove the CB550 rocker arms?
Offline mkramer1121
Re: Removing CB550 rocker arms
« Reply #1 on: June 20, 2007, 09:15:03 PM »
Remove the cap on both ends and all bolts from the valve cover, push the pins out and they should fall out.
newcomtd
« Reply #2 on: June 20, 2007, 09:22:37 PM »
Will the pins really just push out?  They seem to be a VERY tight fit.  Should I tap them out with some sort of drift?
Offline turboguzzi
« Reply #3 on: June 20, 2007, 09:41:56 PM »
"Will the pins really just push out?  They seem to be a VERY tight fit.  Should I tap them out with some sort of drift?"
good that you asked!
"Remove the cap on both ends and all bolts from the valve cover, push the pins out and they should fall out."
would be good if some people would think/check twice before giving dangerous advice!
before being able to pull out the rocker shafts you need to loosen the four bolts under the breather cover and push out the four tappered pins that lock the shafts in place.
then simply screw a 6 mm bolt into the shaft ends to pull with
cheers
TG
« Reply #4 on: June 20, 2007, 11:51:51 PM »
There are two styles of rocker shafts for the 550, one shaft for each (8 total) and 1 Shaft for two (4 Total).  The later has locking pins, the former doesn't.
Honda supplied the newer 4 shaft cover design on CB550K  Engine # 1083641 and subsequent and CB550F  Engine # 1133172 and Subsequent.
In both cases, the cam cover should be removed, the end caps/plugs removed and the shafts withdrawn from the cover to release the rockers.
Removing the cover releases the valve spring pressure on the rocker and shaft.  If you have locking pins, then that also must release to extract the shafts.
Reassembly is where you can do real damage if you don't back all the adjusters out fully and unsure they don't catch on the valve stem when tightening down the cam cover.  There is a specific warning in the shop manual about this.  And, if unheeded, can resultsand many bent valves that are expensive to replace.
Offline mkramer1121
« Reply #5 on: June 21, 2007, 09:55:02 AM »
Mine did just push out, this was with the cam/valve cover (excuse my terminology) off and every bolt I could see removed.
newcomtd
« Reply #6 on: June 23, 2007, 06:42:11 AM »
Do the pins push out from the bottom of the cam cover?
