Author Topic: Aircraft Remover  (Read 4242 times)
Reagan
Aircraft Remover
« on: June 20, 2007, 08:48:18 PM »
I hear quite a few guys talk about "aircraft remover" to remove old paint down to bare metal. Could someone let me know what "aircraft remover" is and maybe a brand name or two? If it works as slick as everyone says I'm going to be kicking myself for buying a sand blasting cabinet for smaller parts and stand alone sandblaster for the larger parts.
Offline starion88esir
Re: Aircraft Remover
« Reply #1 on: June 20, 2007, 08:50:49 PM »
It is the brand name. Look for it in Wally World in the automotive section in a spray can.
71 CB175 - next project
76 CB750F - current project
Offline Magpie
« Reply #2 on: June 20, 2007, 08:55:55 PM »
I've used a product by mar-hyde called "Tal-Strip II" Aircraft Coating Remover. It's a spray can and very strong stuff. Use it outside, wear gloves and a mask. It takes my breath away for awhile. Does it work - you betcha! Spray it on, let work, scrape off the thick stuff, wash off with a hose then soap and water worked for me. Be very careful with it!!!!!!!!!!!!!!!!!!
Cliff.
Reagan
« Reply #3 on: June 20, 2007, 09:06:36 PM »
This forum is unbelievable. Less that 10 minutes after I posted the question I received the answer. Thanks guys.
Offline Magpie
« Reply #4 on: June 20, 2007, 11:31:12 PM »
Forgot one thing, wear eye protection - it is strong stuff.
Cliff.
Offline .RJ
  • homebase in your airspace
« Reply #5 on: June 21, 2007, 06:04:08 AM »
And long sleeves/long pants... if any of it gets on your skin it will burn like a muthaf#@#%!
Offline hahnda
  • lskdfhs;dljksa;
« Reply #6 on: June 21, 2007, 07:07:32 AM »
Looks like this. Find it where Bondo is sold.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline coolcat2002
« Reply #7 on: June 21, 2007, 07:16:49 AM »
It sounds like Paint Remover:
Here's the low down from Amazon description:
Tal-Strip® II Aircraft Coating Remover is especially designed to remove basecoat/clearcoat systems from today’s automobiles. Removes polyurethanes, enamels, lacquers, primers and most other paints and coatings from aluminum and other metals. Brush or spray on and in minutes the coating will soften. Then flush with water or wipe clean.
I personally used a Paint Stripper Aerosol Can for my tank.  Probably not as industrial.  It wrinkled the paint and I scrapped it off with a putty knife.  I did this twice since there were layers.  Instructions say that you don't second coat it.  Just spray, scrap/ wipe/ wash.  Repeat.
Apparently they have strippers for Powder Coats too!
I didn't use any personal protection gear other than dish washer gloves but it's a good idea as everyone can attest.
« Last Edit: June 21, 2007, 07:19:03 AM by coolcat2002 »
Reagan
« Reply #8 on: June 21, 2007, 07:36:14 AM »
It states that the product works on aluminium. Has anyone used it to strip paint from the crankcases or heads? If, how did it work? The paint on my crankcase is chipped and flaking and I'd like to re-paint the cases and heads using VHT paint.
Offline Rocker
  • The one, the only!
« Reply #9 on: June 21, 2007, 07:39:52 AM »
Man, you think we can get paid for the endorsements in this thread?!?!?
 :P
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline 333
  • Time for change
« Reply #10 on: June 21, 2007, 07:42:30 AM »
I would also be concerned about the surface you are working over.  Cement is pretty indestructable, but asphalt could be another story.  I've seen what plain gasoline can do, i can only imagine what this stuff might do.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline hahnda
  • lskdfhs;dljksa;
« Reply #11 on: June 21, 2007, 07:52:26 AM »
Works great on aluminum. Removes all the crappy, yellowed clearcoat found on these Hondas.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline greenjeans
  • 1972 CB750K2
« Reply #12 on: June 21, 2007, 08:22:40 AM »
It comes in a brush on too... that's what I used
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #13 on: June 21, 2007, 08:30:38 AM »
Your blasting setup will always be better for those hard-to-reach nooks and crannies.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline hymodyne
« Reply #14 on: June 21, 2007, 06:41:51 PM »
the spray is the most cost effective thing, I think. the media cost and time spent in preparation to blast a tank or frame is much longer than the time to don mask goggles and protective clothing and spray. and about $12.00 for two cans of remover. I follow with a jitterbug and 100 grit and I've got nice shiny pieces.
hym
Offline cleveland
« Reply #15 on: November 19, 2007, 04:13:09 PM »
Any reason to use this brand over any other paint remover for metal surfaces?  I picked up some stripper from Home Depot that is for metal surfaces and I though I would ask before I strip my frame and tank.
Thanks!
Offline rbmgf7
  • 2>4
« Reply #16 on: November 19, 2007, 05:01:27 PM »
never used the actual aircraft remover brand but i've used citri-strip. the odors isn't as harsh as some other paint remover brands making it easier to deal with indoors. leaves a nice orange-ish smell. you can find it in the solvents/paints area at wally world. comes brush on and spray.
Offline hahnda
  • lskdfhs;dljksa;
« Reply #17 on: November 20, 2007, 07:27:07 AM »
Aircraft stripper kicks the Home Depot stripper's butt.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #18 on: November 20, 2007, 12:40:06 PM »
No need to kick yourself for getting the blasting cabinet. If you do many of these old bikes that cabinet becomes a necessity.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
Offline greenjeans
  • 1972 CB750K2
« Reply #19 on: November 20, 2007, 01:08:19 PM »
Amen to the blasting cabinet.
That IS my next tool pruchase.
Offline rbmgf7
  • 2>4
« Reply #20 on: November 20, 2007, 02:49:52 PM »
well, your blaster is only as good as your compressor. no less than 11cfm, 60 gal. for good, continuous blasting.
there's also siphon feed blasters. it's basically the actual blasting part without the cabinet. cheap too. can get one for about $10. wally world use to have them but can find them at a local farm supply store. i built my own cabinet with 2x4's, 1/8" plywood, and a sheet of lexan. i installed a light that i had lying around. saved mucho $ and worked well for small parts.
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
« Reply #21 on: November 21, 2007, 01:04:01 PM »
I've used MarineStrip for stripping paint.  Not too stinky.
Enjoying life, one day at a time.
Offline chopstar500
  • King of the Nighttime World
« Reply #22 on: November 21, 2007, 01:29:13 PM »
Wurth products makes a great gasket/paint stripper - best I've ever used. And trust me, I've used a lot - killed more than my fair share of brain cells. And no... I did not get a thank you card from the earth for using these products. Excuse me, as I know have to itch my third ear.
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
