Author Topic: normal oil pressure  (Read 944 times)
Offline snyquist53
  • party time
normal oil pressure
« on: June 21, 2007, 12:34:22 PM »
i got 60 at start up.  is that alot for a 74 750
74 cb750, 71 cb450, 77 cb550, 74 cl350, 74 sl200, 00 vt110, 77 sporty ironhead
DOG PILE
Offline Bob Wessner
  • "Carbs Suck!"
Re: normal oil pressure
« Reply #1 on: June 21, 2007, 01:04:02 PM »
No, about normal, but it does depend on some things. What weight oil you are using and what the ambient temperature is. I use 10w40. When warmed up, I get about 10 lbs per thousand RPM. At startup it can run 60 if it is a warm day, or as much as 80 lbs if it is cool, such as 50 degrees or less.
Offline snyquist53
  • party time
« Reply #2 on: June 21, 2007, 04:05:15 PM »
i'm using honda oil 10w-30.  it is kinda hot today.
DOG PILE
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: June 21, 2007, 04:10:20 PM »
10w30 is a bit light for a 750. Some even run 20w50 in the hotter climates.
Offline jaknight
  • ....Round Town Ride......
« Reply #4 on: June 21, 2007, 05:20:24 PM »
Hi Guys,
     I have a '74 CB750 K4.  During the "cold" months (if there is such a thing in The Valley of the Sun, Phoenix, Arizona), I use 10W40W.............. I read about 72 pounds at start up/warm up.
     As the weather heats up here, like now at 114 degs, I have already switched over to 20W50W, and though the oil is thicker, the heat more than compensates for the oil viscosity change.........  At engine start up, I am still reading the same, 72 pounds............ seems to balance out perfectly........
     By the way, I have 26,750 miles on my 750............. just a thought........
     I really feel that my engine needs the oil protection change due to the phenomenal heat here............ I think only Death Valley beats us out............ ;) ;)
     ~ ~ ~ jaknight ~ ~ ~
« Last Edit: June 21, 2007, 05:27:48 PM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
