Author Topic: anyone know cb450T carbs?  (Read 1372 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: June 22, 2007, 01:07:22 PM »
i've spent a lot of time with the 350 twins, and of course the fours, but this is my first cb450 ('74).
when cleaning the carbs, i discovered that the pilot jets don't seem to have an orifice in the float bowl. there are two holes beneath the threads (above in a gravity sense) that look like emulsion holes, and then the hole at the top where the fuel enters the throat. my usual experience with pilot jets (as with the 350, 400, 500, 550,650, and 750) is that the fuel passageway is a straight shot through, with air-emulsion holes in the middle. though i've rebuilt a thousand cb350 carbs, the functionings of all of the inner passageways on these 450 CV carbs are a bit of a mystery at the moment. am i wrong and there is in fact a plugged hole in the slotted end of the jet? it really appears to be solid brass. or does the pilot circuit somehow pull fuel from somewhere else?  ???
« Last Edit: June 25, 2007, 12:57:30 AM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: anyone know cb540T carbs?
« Reply #1 on: June 22, 2007, 01:22:48 PM »
Hey Paul,
I've seen some pilot jets that are not straight-through. There are holes on the sides that the fuel passes through, a lot like the little holes on the main jets of the cb's.
Do these carbs have that?
No.
Offline paulages
  • 1976 cb735
« Reply #2 on: June 22, 2007, 01:40:33 PM »
yeah, they do. but the bottom of the jet still sits in the bowl, and the holes are above the threads and not in the bowl.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: June 22, 2007, 01:43:14 PM »
SP there's no way for the fuel to pass through to the holes...?
No.
Offline paulages
  • 1976 cb735
« Reply #4 on: June 23, 2007, 12:22:33 AM »
ok, as usual i figured it out myself. i always know i can, but end up looking for quick help. the pilot jet feeds fuel through the main jet. strange arrangement, but it obviously works.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
