Author Topic: aluminum cleaner  (Read 2160 times)
Rocking-M
aluminum cleaner
« on: June 23, 2007, 04:14:58 AM »
What is the best thing to remove oxidation from our aluminum engines with?
I don't want a polished look, just a non-blotchy even clean look.
I'm not tearing the engine down and have done a few parts with that
acid wash cleaner which works pretty good but I don't want to
spray the whole engine with it. Some sort of paste cleaner
is what I think would work best, and a tooth brush :)
Offline 736cc
Re: aluminum cleaner
« Reply #1 on: June 23, 2007, 05:40:30 AM »
Remove covers from the engine. You can do this procedure w/ covers on engine in frame but you'll get better results w/ a little dismantling. Chemically zip-strip the factory clear lacquer, then etch them w/ hydroflouric acid (Mothers Wire Wheel and Chrome Cleaner) while rubbing w/ 000 steel wool then rinse w/ plenty of water. Now polish w/ 000 steel wool w/o adding any polish paste. You can give a final rub w/ 0000 if you want a finer finish. Use Penetrol as a polishing lube, which also works to rejuvinate nuts, bolts, plastic, metal, and frame paint. You can clear w/ Eastwood metal clearcoat in a rattle can, which will add some durability and will approximate the orig clear. Or leave the aluminum bare and rub once  or twice a season. DEFINATELY wear HD rubber gloves and eye protection when using these harsh chemicals!
You will be more than happy w/ the results. I use this technique when I want to give the motorcycle a super-clean original "unrestored" look, which is compatable w/ original paint, chrome, gauges, spokes, nuts, bolts etc.
« Last Edit: June 23, 2007, 05:52:55 AM by 736cc »
Rocking-M
« Reply #2 on: June 23, 2007, 08:19:55 AM »
Hey that's the look I'm after. Don't want it to look to restored just cleaned!
Thanks, Robert
Offline Klark Kent
« Reply #3 on: June 23, 2007, 08:43:01 AM »
it doesn't look like you have had any ill effects from applying steel wool to aluminum, which i thought i remembered reading here would lead to steel particles oxidizing the aluminum, or accelerating oxidation where the particles are left in/on the aluminum.   ???
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Rocking-M
« Reply #4 on: June 23, 2007, 09:00:59 AM »
Hey Klark, you still heading down this way? If and when be sure to holler at me!
I used steel wool on my wheels and it really cleaned them up great.
Offline Klark Kent
« Reply #5 on: June 23, 2007, 10:14:40 AM »
hey RM
i wish i had more free time when i was in VA.  i spent about 3 hours a day awake where i wasn't working or riding to/from work.  Made a good pile of dough, so now i have some free time and might revisit the area for fun- and if i did i would head straight for the mountains, so I'll let you know.- today would have been perfect for a trip like that- damn hangovers...
anyway about your polish question, steel wool is great on chrome(ium steel) but that is steel on steel, and i might be mistaken (i'm the one who wet sanded his chrome) but i could have sworn that i read steel wool would leave little specks of steel in the aluminum, which would lead to white specks of corrosion popping up.  but 736cc's bikes all look so badass that i am questioning this....  :-\
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
