Author Topic: point gap setting  (Read 990 times)
Offline johnyvilla
point gap setting
« on: June 23, 2007, 07:39:54 PM »
Hey guys. I installed new condensers and points on my 750k6 the other week and just got around to checking the timing with a gun. The f2-3 mark lines up nicely but the f1-4 jumps all over the place when lined up. I re-gaped the points several times, strobing it afterwards with the same results. Valves are within spec, carbs rebuilt-synced and motor revs nicely. Any ideas why the F1-4 mark would jump back and forth? thanks.
Offline johnyvilla
Re: point gap setting
« Reply #1 on: June 24, 2007, 05:27:26 AM »
No one has any ideas huh? Forgot to ad that the left point, although new, does not seat perfectly. There is some play in the top part of the mechanism.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: June 24, 2007, 06:11:13 AM »
That could be your problem. Who made the points you are using? They cost more, but I would go with Honda points if they are not OEM.
Offline 333
  • Time for change
« Reply #3 on: June 24, 2007, 06:28:46 AM »
Could be the points plate, also.  And I agree with Bob, stock is trick.  And in the case of points, it's still available.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
