Author Topic: REALLY Stuck Caliper  (Read 3042 times)
Mr. Dave
« on: June 24, 2007, 02:24:27 PM »
Are there some magic words and tricky phrases needed to get a stuck caliper out of the housing.  I haven't found anything I can grab it with.  thanks guys.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: REALLY Stuck Caliper
« Reply #1 on: June 24, 2007, 02:28:18 PM »
"Clatu Verata Nictu."
Seriously, try backing out the bolts a little and squeeze the brake.  Back the bolts out a little more, squeeze again. Repeat until you've got it out.  Hopefully some experts will chime in, but that's how I got mine unstuck.
1977 CB750
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 24, 2007, 02:45:23 PM »
I'm a little confused.  Are you talking about the piston being stuck in the caliper?  If so, remove the caliper from the fork with the brake line still attached and pump it out with the brake lever.
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #3 on: June 25, 2007, 06:57:14 AM »
You can also pull the caliper off, and gently screw the end of a grease gun into the hole that the brake line attaches to.  Gently because the thread patterns are't exact, so you can only get a turn or so in, which is all you'll need.  Then pump the grease gun and it will pop out the puck nice and gently.  Hitting it with an air gun tends to send the puck flying across the room.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #4 on: June 25, 2007, 07:11:22 AM »
second the grease gun, only I attach the gun to the bleeder nipple and screw a solid bolt into the banjo fitting threads.
dave
Offline hopterfixer
    • My flickr Gallery->
« Reply #5 on: June 25, 2007, 10:49:15 AM »
Third the grease gun.  There is a topic in the tech tips concerning this.
http://www.sohc4.us/forums/index.php?topic=15059.0
Mr. Dave
« Reply #6 on: June 25, 2007, 06:40:41 PM »
Thanks troops< there's nothing like experience!
Offline hopterfixer
« Reply #7 on: June 25, 2007, 08:53:46 PM »
I thought mine would never come out until I read about the grease gun trick.  ;)
ClassicGlory
« Reply #8 on: June 27, 2007, 11:26:22 AM »
Just to prove I am real di@khead I used an airline.... and the puck flew across the garage.
Mind you, it didn't damage it and it did come out and I don't have a big enough grease gun.
It did scare the cr@p out of me though.... boy did it fly!
Regards
Chris.
Offline csendker
« Reply #9 on: June 27, 2007, 07:37:42 PM »
My grease gun uses mini cartridges and cost about $5 at K-mart.  It's not the size, but the hydraulic pressure from really incompressible stuff like grease that does the trick.
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« Reply #10 on: June 28, 2007, 06:09:34 AM »
Re: the flying across the garage thing.  Just put a nice soft folded towel or something on the bench and make sure the piston is facing downward.  It worked for me.  I also do a small shot of air every couple of seconds so it doesn't build up so much.  My particular grease gun wouldn't work so I had to use the compressor.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Offline joeb
« Reply #11 on: June 29, 2007, 03:54:36 AM »
I use air pressure.
Offline Tvag
« Reply #12 on: June 29, 2007, 05:44:40 AM »
I took the caliper off and pumped it out using the brake lever, but I had to bleed it first.
1977 CB550K (on the road, FINALLY! 4/10/08)
1979 Kaw Z400B2 (someone's future parts bike)
tmht
« Reply #13 on: June 29, 2007, 07:02:50 AM »
Be aware that if you already tried to use pliers to pull the piston out of the caliper you may have already done irreparable damage to the piston. Inspect it carefully for tool marks at or below the point were the piston meets the seal. You may be able to polish them out with no ill effects, but if you find any tool marks or gouges there, expect that your piston will no longer retract correctly.
Offline Chris Liston
« Reply #14 on: June 29, 2007, 07:36:44 AM »
air comp all the time.  Who wants to clean up grease :(    Put the caliper puck side down onto a towl.  Place air comp nipple into brakeline area and POP.
1976 CB550F Cafe in progress
Offline boatsdickson
  • 1978 836 K8
« Reply #15 on: July 03, 2007, 06:53:42 PM »
From recent xperience, 90pounds from the compressor will loosen any piston you got. It will also send the piston across the shop, put 2 chips in the concrete between my car frame and the floor while it bounces off momentum, and send my wrench getter runnin for the house.
« Last Edit: July 04, 2007, 07:10:58 AM by boatsdickson »
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline bradweingartner
  • 74 CB 550 x2
« Reply #16 on: July 07, 2007, 09:47:34 AM »
I've had a couple that air just wouldn't do the trick for. So now I just pull off the caliper stick it in a plastic tub and pump the brakes/add fluid until the piston pops out. No grease mess, and it cleans out the master cylinder with clean brake fluid too.
If your piston is in good shape air seems to work. If you're in need of a new piston, it catches on the corrosion. I'm making/selling stainless steel pistons to alleviate this pain in the bum.
