Author Topic: oil leak on 550  (Read 1000 times)
BruceA cb550
oil leak on 550
« on: June 25, 2007, 01:14:15 PM »
just recently thoroughly cleaned and painted the engine, now I notice a small smearing of oil which appears to be coming from between the head and cylinder on #1.  Engine runs good, compression is good, and plugs are clean.  This leak may have been there before cleaning but wasnt as noticable due to other crud.  Engine has 22,000 on it.  Is this common to have a tiny leak or is this something to investigate further.   ???
Offline cleveland
Re: oil leak on 550
« Reply #1 on: June 25, 2007, 01:18:15 PM »
Mine has the same.  I just deal with it.
Offline OldSchool_IsCool
  • Really feeling like an
Re: oil leak on 550
« Reply #2 on: June 25, 2007, 01:31:42 PM »
Bruce,
Yep! very common.  I take a rolled up paper towel and cram it between the fins to catch the oil and therefore save my pants.  Change the wadding when saturated.  I've also heard that a short length of cotton clothes line works great for this "fix" too.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: oil leak on 550
« Reply #3 on: June 25, 2007, 02:56:57 PM »
A very common problem, found throughout the range, I believe. My 650 does it too. The rubber O-rings inside the head around the oil feed galleries dry up with time/heat, and Roberts your mothers brother, the oil starts making an appearance outside.
The fix is to wait until your next top end tear down, then replace the pesky items.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
