Author Topic: To re-ring or not?  (Read 865 times)
rsvp9146
To re-ring or not?
« on: June 26, 2007, 09:02:50 AM »
Long story short, I picked up a CB550K with a rebuilt head that was never put back on. Would it make sense to re-ring the pistons while I’ve got the head off? Odometer shows 3500 miles, but who knows if that’s accurate. The reason I ask is because I should replace the cylinder base gasket. Re-ringing would be easy. How long do these rings typically last?
 What do I need to know about honing the cylinders? Stone or grape hone? How much? Where can I buy rings?
Offline dusterdude
Re: To re-ring or not?
« Reply #1 on: June 26, 2007, 10:25:11 AM »
i would say,as far into as you are,why not?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline merc2dogs
« Reply #2 on: June 26, 2007, 11:32:22 AM »
 Always been my philosophy, if you're tearing into it, why not make it better?
  Would be a real pain to get it together and find out it has lousy compression.
Ken.
rsvp9146
« Reply #3 on: June 26, 2007, 02:21:40 PM »
Yeah, I figured as much
either of you know how much to hone the cyls?
Also, where do I find rings? any special procedures for adjusting the end gaps if needed?
