Author Topic: plug caps  (Read 1356 times)
Offline hymodyne
plug caps
« on: July 01, 2005, 12:29:57 PM »
Hi all,
I've got problems with cylinders 3 and 4. I started the bike and those pipes are cold. when I put an spare plug into those caps, I get a visible but weak spark. with my ohm meter set on 20K, they read 8.6 (#4) and 10.4 (#3) ohms. These are replacement coils (used) from a '72 cb500.
the carbs have been rebuilt and completely overhauled, and at times, all four pipes have been hot--just not 3&4 right now.
suggestions?
hym
Re: plug caps
« Reply #1 on: July 01, 2005, 02:39:31 PM »
It would be interesting to know what the resitance of the 1&2 plug caps are.  And, if you swap them with 3&4 does the problem move with the plug caps?
Are your plugs clean?  Dry or wet?
Are you using resistor plugs?  What is their number?
What is the voltage across each set of open points?
Are you using the stock, points, etc?
Are there any cracks in the ignition lead wires?
Re: plug caps
« Reply #2 on: July 02, 2005, 03:20:31 AM »
Cant be the coils as 3 & 4 are off seperate coils
