Author Topic: Paint Experts: Is there such an animal as Aluminum Paint?  (Read 2039 times)
Offline 736cc
« on: June 27, 2007, 07:40:04 PM »
Aluminum bodywork looks way-cool. Can aluminum be spray-painted on? I wonder if its possible to replicate a "brushed aluminum" finish by painting with an aluminum base paint then brushing it w/ steel wool?
At the same time, if aluminum based paint is available, can it be polished?
I've seen it used w/ ceramic coating on engine covers, but it requires 600 degree curing temps.
Offline xtalon
Re: Paint Experts: Is there such an animal as Aluminum Paint?
« Reply #1 on: June 27, 2007, 08:34:46 PM »
There's chrome paint, but I'm not so sure about aluminium.  After a quite a bit of research on my part, Alsa Corporation probably makes the best chrome paint and within about a week, I will be using it on my project.
http://www.sohc4.us/forums/index.php?topic=21578.0
However, being paint, I don't know how it would work trying to get a brushed effect using steel wool.  If we have something to try it on when we paint my tank, I my try it and let you know, but I can't promise anything.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline merc2dogs
« Reply #2 on: June 27, 2007, 09:27:27 PM »
 There are a few decent aluminum colored paints, as for the brushed look, I -think- you could duplicate the look using the same techniques they use for wood graining. Need to do a search for that though, some can be done so well that there is NO visual evidence that it's not real wood grain you're seeing, they sell graining rollers for that, but the best work is done with combs
 I think if you approached it with two slightly different colored paints, spray the darker on, let it dry, then spray the lighter on and then brushed it lightly with a wide paint brush and afterwards sprayed it with clear you'd have a good effect. If you look at painted woodwork you'll see the brush strokes normally done by accident because there isn't enough paint on the brush, that's the look you want to produce on purpose, the clear is so it doesn't look or feel the same way.
 Though I think if I wanted to duplicate the brushed aluminum look on a steel panel, I would brush the steel first then paint it with a couple light coats of the best aluminum paint I could find.
Ken
Offline kghost
« Reply #3 on: June 28, 2007, 02:52:40 AM »
Most of the brushed aluminium "looks" I have seen have been airbrushed.
I've been curious for years as to how nitrate/buterate dope would work for the same effect.
The first couple coats when refinishing fabric aircraft contains aluminium pigment and would giv the brushed look you are looking for...just dunno how well it would stick.
Stranger in a strange land
Offline 736cc
« Reply #4 on: June 29, 2007, 06:36:33 PM »
OK, I found the paint I need (House of Kolor Kosmic Khrome MCC-01)  http://www.houseofkolor.com/hok/PDF/HOK_KK_ABA.pdf
The paint finish resembles polished aluminum; brushed aluminum is acheived by Scotch-briting the surface before spraying.
Now I need a pro thats familiar w/ using this product. Any air-brush experts here that can paint my ride?
« Last Edit: June 29, 2007, 07:29:53 PM by 736cc »
ZetecOwns
« Reply #5 on: August 09, 2007, 08:10:39 PM »
Just a thought, because I too have thought about the brushed aluminum look.
Couldn't you simply take your metal (tank, cafe seat, what have you) down to bare metal and sand/buff to get the brushed marks, then spray on a clear coat (rustoleum makes one) to protect from rust?
Seems like it would look cool. I'm still half considering it.
Offline xtalon
« Reply #6 on: August 10, 2007, 04:24:22 AM »
As long as the metal is scuffed enough to give the clear something to adhere to, I think it should work, but I'm no expert, so do some more checking before you try it.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
