Author Topic: oil consumption  (Read 1733 times)
Buffo
oil consumption
« on: July 01, 2005, 09:45:02 PM »
How much oil consumption is normal for these old girls?  Say in between oil changes.
I have the infamous 1978 CB750K8.
I have known some big southern women that carried a cold piece of fried chicken wrapped in foil in their purse just in case they got a little light headed. ;D
do any of you folks have to carry a quart oil just in case your girl gets a little low?
This is my first cb so ...
Don
« Last Edit: July 01, 2005, 09:50:12 PM by Buffo »
Offline Gordon
  • 750K1, 550K2
Re: oil consumption
« Reply #1 on: July 01, 2005, 11:10:33 PM »
I put in probably 1/2 quart between oil changes, and I suspect most of that is probably from the slight weep from the valve cover gasket on the left side.  I do carry a rag to occasionally wipe the head to keep the oil from spreading down the front of the engine, though.  If you have to carry a quart to keep it topped off, it may be time for a top end rebuild.
Offline oldbiker
  • I HATE RAIN
Re: oil consumption
« Reply #2 on: July 02, 2005, 01:05:44 AM »
My CB400f uses virtually no oil between oil changes. If you're having to carry oil on longish journeys then either you have a leak somewhere or the top end (valve guides etc) are worn and need attention.
Buffo
Re: oil consumption
« Reply #3 on: July 02, 2005, 02:57:05 PM »
i HAVENT EVEN GOT TO RIDE MY BIKE YET.
i WAS JUST WONDERING if it was a common thing.
Don
Offline Gordon
  • 750K1, 550K2
Re: oil consumption
« Reply #4 on: July 02, 2005, 06:12:59 PM »
Sorry, not mind readers here.
Hope you get to ride it soon!
eldar
Re: oil consumption
« Reply #5 on: July 04, 2005, 02:38:59 PM »
Ok well my bike has about 14000 miles on it. I have the EXACT same bike you have. NO oil usage at all that I can find. Other than my seal for my tach cable is bad. If you have no visual leaks, then I would check compression. Average seems to be around 135 for a compression reading. If you ahve low numbers then that would indicate that the problem is either with the rings or valves probably.
