Author Topic: Polishing Stainless Steel?  (Read 648 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
« on: June 30, 2007, 04:34:25 PM »
 Bought an Enduro, and it's equipped with Stainless Steel front and rear fenders. They are not rusted or dented, just dull. What's the best way to polish them up? Not to a "Chrome" luster, but not dull. Can it be done with elbow grease or do I need a bench-mounted polishing wheel? What's the best compound to use?
Re: Polishing Stainless Steel?
« Reply #1 on: June 30, 2007, 05:22:04 PM »
You can use a wheel mounted on a drill. I would start with red rouge and work to white. It will have a smooth luster.
tbone
« Reply #2 on: June 30, 2007, 05:41:19 PM »
Clean them first with a stainless cleaner like "Sparkle". (comes in a spray can)
Then you may only need Simichrome and some old fashioned elbow grease.
Offline 736cc
« Reply #3 on: June 30, 2007, 08:49:38 PM »
Deloreans and ss appliances get scratches/blemishes removed w/ fine steel wool, parrellel (not orbital) rubbing. SS cleaner available in hardware and grocery stores
« Last Edit: June 30, 2007, 08:51:09 PM by 736cc »
