Author Topic: Jetting and sprocket question?  (Read 1098 times)
Offline cb750frank
« on: July 01, 2007, 06:14:58 PM »
 Can anyone give me a ballpark main jetting on a 1975 cb750k5 with a 4 into 1 header and pod air filters. the header is currently open but I will be adding about a foot of exhaust pipe to it. Do I also have to change the idle jets? Do I have to adjust the air mixture screws.  My second question is regarding sprockets. I need a new chain and sprockets. I would like my bike to power wheelie if possible. What sprocket sizes would achieve this. I would still like the bike to be able to go 100 mph. Any help will be greatly appreciated. thanks again!!!!!!
Offline johnyvilla
Re: Jetting and sprocket question?
« Reply #1 on: August 15, 2007, 07:12:18 PM »
Id think at least 125# Mains and 42# pilot.
Offline KB02
« Reply #2 on: August 16, 2007, 04:41:47 AM »
Well, I have pods and aa stock 4-into-1. I'm currently running 120's and it is just a touch on the rich side. I'd say start there and test it a bit (Plug Chops) to see if that works for you. You may need the 125's, too, with the open header.
As for the Wheelies, I would think you would want a smaller front and/or a larger rear sprocket. What gearing are you running now? Stock? Try dropping the front down one tooth. That will give a little extra grunt on the bottom and not take away too much top end. Remember, though, that these are 30+ year old bikes that are heavy and not realy as powerful as modern machines. Wheelies are going to be tough to get out of them.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline kghost
« Reply #3 on: August 16, 2007, 08:42:21 AM »
I've found they wheelie just fine  :D
The sprocket and wheelie question has been covered many times...
Use the search function.
Stranger in a strange land
