Author Topic: 6 volt CDI?  (Read 2516 times)
Offline jaguar
6 volt CDI?
« on: July 05, 2007, 03:24:38 PM »
ill start off by telling you all that im an electrical morron....
i want to upgrade to a CDI on my 74 CL125 land speed bike.  its still a 6 volt system.  i can only find the set ups for those honda pitbikes.  also for those baja bikes they sell in pepboys.  all those are is crappy honda replicas.  but they are 12 volts.   does that matter?  or better yet anyone do a cdi on a old CL/CB/SL/XL/TL 125?
Offline mack808
Re: 6 volt CDI?
« Reply #1 on: July 08, 2007, 02:43:49 PM »
The '81-'82 CB125 had pointless ignition, and these were the same parts as the early ATC200s' used. The CB125s were still 6volt, so I would assume with pulse coil, advancer and 2ndary coils all of the same type you should be able to use those items.... I may actually have a pulse coil and 2ndary from a '84 ATC200S....  if you cant find anything locally, let me know....
CB350 twin vintage road racer, CB350F project, GS750es daily rider, NS400r play bike, 2 MB5s, Z50r project, CB500/590 vintage racer built for friend, CT200 project, and a Gina (Gilera copy made in Argentina)...  And ?????
Offline jaguar
Re: 6 volt CDI?
« Reply #2 on: July 19, 2007, 03:46:16 AM »
is teh ATC200s a 6 volt?   so it should be and easy swap?   got any pics and sizes of the set up?
im interested thanks
Offline crazypj
  • I'm brill, me
Re: 6 volt CDI?
« Reply #3 on: July 19, 2007, 10:42:21 AM »
With an AC CDI the generator supplies voltage so it isn't 6 or 12 volt. You only have that for battery charging.
 You could probably fit complete generator from XL125S or any of the XR185/200's although you will need the CDI unit.
 I think I have some cam trigger units somewhere, the mechanical ATD and probably backing plate etc.
PM me if your interested, I'll dig about for parts
PJ
