Author Topic: chain adjustment question  (Read 902 times)
Offline neil young
  • striving to be an
« on: July 07, 2007, 09:31:43 AM »
i tried adjusting my chain last night.i cannot get the lines on either side of the bike to line up.for instance there are 6 line up marks on either side of the swing arm.on the left side of the bike the line is inbetween the forth and fifth mark.on the right side it is on the third mark.in the manual it say to line up both evenly.i tried on my other bike and pretty much the same thing.so when i spin the tire freely it has a wobble to it on both bikes.am i doing something wrong.i loosened the nut 3 turns and adjusted as stated in the manual.the left (chain side) is much tighter than the right side on both bikes.when i tried to get get both side even the tire wont turn freely :-\
« Last Edit: July 07, 2007, 01:23:48 PM by neil young »
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline jaknight
  • ....Round Town Ride......
Re: chain adjustment question
« Reply #1 on: July 07, 2007, 10:56:42 AM »
Hello Neil,
     I am not familiar with the 500 models, but.......
     If they are anything like the CB750's, you must undo the brake linkage to the rear wheel.  On the 750, there is a round rod that is spring loaded with a nut on the end to keep it in place.  This must be undone....... remove the long rod from its retainer, so that it does not bind, put the spring and nut in a safe place to refit them after your chain adjustments.....
     Once again, also on the 750, there is a flat brace that connects to a bolt through the brake drum itself, to keep the drum stationary when the internal pads are pressing against the inside of the drum.  This brace/bolt must also be undone......... remove the brace from the bolt, do not undo the other end of the brace; it's best to leave the bolt in place on the drum.......
     These two components must be temporarily removed so that the rear wheel is free to move forward or backward, once the axle is loosened, and the wheel may move without binding.....
     This is true on the 750.............. I do not know for sure on your bikes........ but, with this in mind, you can take a look and see if your bikes have these components.......
     Good luck.......... ;) ;)
     ~ ~ ~ jaknight ~ ~ ~
« Last Edit: July 07, 2007, 11:14:18 AM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
