Author Topic: dunstall fender/ fork stabilizer brace?  (Read 3014 times)
Offline jevfro
  • 1975 CB750 K5
« on: July 10, 2007, 08:26:07 PM »
I've looked at many posts and at pictures of dunstalls like these...
I haven't found out how, or if, the forks were linked using fork braces or other stabilizers.
Is it possible that these fenders don't need anything but the hose clamps around the fiberglass fender to make the forks work together and reduce wobble?  I thought there would be something else, but I cant make-out a brace or other stabilizer in any of the photos I've seen.
Are fork braces not as important as I assumed they were?  I see race bikes with no front fender and no bracing.  I just got a fender off ebay and want to install it but I'm a lil' concerned about the lack of fork stabilization.   What gives?
Offline jevfro
  • 1975 CB750 K5
Re: dunstall fender/ fork stabilizer brace?
« Reply #1 on: July 11, 2007, 07:40:23 AM »
bump.. no answers? Any thoughts?  I know there are at least a couple of dunstalls out there. Superbiker_UK? Seaweb? do you guys still have a Dunstall front fender? how is it at speed? forkbrace? or just hoseclamps...
Thanks!
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #2 on: July 11, 2007, 08:01:29 AM »
I have had several of those and similar fenders that simply were clamped to the fork when I got them. I usually pitch the front fender anyway so I haven't tried to use a brace with one.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline jevfro
  • 1975 CB750 K5
« Reply #3 on: July 11, 2007, 08:06:42 AM »
Thanks Chung! I'm starting to believe they were just run w/o any bracing but I wanted to know others experiences.  Thanks for the info!
Offline Jim F
  • go baby go
« Reply #4 on: July 11, 2007, 10:47:38 AM »
The Dunstall finder that I have is only clamped with very small hose clamps
the finders are very strong and stable. Atleast for my application
If you look close in the pictures you can see the clamps.
they don't look the best but work fine with my "dunstall racer" that I am building
great pictures though
Jim
« Last Edit: July 11, 2007, 10:51:05 AM by big-jim »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline DME
« Reply #5 on: July 11, 2007, 11:07:40 AM »
I´ve been running my 750 with a flimsy Rickman-replica front fender that is only attached with hoseclamps.
No problems.
Personally I think forkbraces are a bit overrated.
Make sure your chassis is good:
- true wheels
- good wheelbearings
- steering head bearings
- swingarm bushes
- rear shocks
 etc...
I´ve been pushing my bike qiute hard with not as much as a tendency to a wobble.
Cheers
Dan
Offline jonbuoy
    • My rebuild:
« Reply #6 on: July 11, 2007, 12:52:59 PM »
I looked at getting an airtech fender,its says in their website to drill out the rivets holding the old fender on and use the bracket with the new fender.
Caferacingparts
« Reply #7 on: July 11, 2007, 03:24:52 PM »
  Dunstall didn't use fork braces, the fiberglass fenders were simply clamped or bolted to the forks. Over the years fork braces have become more usefull as tire technology has progressed. As racing compound tires have increased grip, frame and fork flex has become a more significant issue. If your riding will be mainly on the street, running without a fork brace shouldn't be a problem.
                      Cheers, Bret @ Glass from the Past
Offline jevfro
  • 1975 CB750 K5
« Reply #8 on: July 11, 2007, 04:36:56 PM »
Thanks everybody!  I think I'll just use the clamp method as I'm not near any tracks.  I had thought about drilling out the old brace from the original fender but I don't think it will fit under the Dunstall fender (replica).  It is fairly thick (3/16") and has a pronounced angle at the top and I think the brace would make it ride way to high and not look right.
Offline hymodyne
« Reply #9 on: July 12, 2007, 02:45:29 PM »
that's what I did. the front fender in my avatar is off a nighthawk and didn't have an internal fork brace. I ground out the rivets from my stock fender and installed the brace uinderneath the new fender.  works fine.
purveyor
« Reply #10 on: July 17, 2007, 08:33:08 AM »
Great Day,
are fork braces available ???
i have stock 78 750 F2 front end with a full Veter mounted
have a shimmy at 80-100 miles
ya...slow down..two wheels are fast
it looks like there is some room to mount braces
i would like something era specific
thanx
