Author Topic: Igniter Mounting Location On An 80' CB750K?  (Read 1558 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: July 13, 2007, 02:47:23 PM »
     Okay, here's what I've got. As the title reads, I have no idea where the 2 igniters on my 80' CB750K are supposed to be mounted.  ::) When I got it, they were just plugged into the wiring harness and dangling behind the left sidecover. I have looked the area over, checked the manual (a Clymer's) and have not figured out where they should bolt to. :-\ Any input here, would be appreciated.
                              Later on, Bill :) ;)
Member # 1969
jdigga
Re: Igniter Mounting Location On An 80' CB750K?
« Reply #1 on: July 13, 2007, 03:09:05 PM »
Stand by, Bill, I'll have pics for you shortly...
jdigga
« Reply #2 on: July 13, 2007, 03:16:16 PM »
Okay, here you go.  They mount behind the battery box as shown:
Above view from left side:
View under left side cover:
Offline bill440cars
« Reply #3 on: July 13, 2007, 06:29:57 PM »
      Hey jdigga,
                   Thanks for the info and pictures. Now, I gotta go check mine out. I musta looked for the mounting place a hundred times and I knew that it should be real close because the wires aren't that long. I have no idea why it took me SOOOOOoooooo long to think about asking the question here. ::)
Member # 1969
Offline bill440cars
« Reply #4 on: July 13, 2007, 08:35:08 PM »
      Well, mine is built basically like the one you posted, except my rear inner fender has a built-in toolbox right behind the battery carrier and the battery carrier doesn't have a mount tab right there. There is a tab not too far away from there. I'll have to do some monkeying around with them and see if I can mount them there. I sure can't have them just dangling there. If that doesn't work, I may have to fabricate something. Here's what my inner fender looks like.
Member # 1969
jdigga
« Reply #5 on: July 14, 2007, 06:57:09 AM »
Hmm, does you battery carrier look like the one in the box?  That tab sticking out on top looks promising.
I think mine is the other one.  Anyway, that tab you found nearby must be the ticket.
« Last Edit: July 14, 2007, 06:59:17 AM by jdigga »
Offline bill440cars
« Reply #6 on: July 14, 2007, 10:50:57 AM »
       Yeah, that tab might be it. I'll let you know what I come up with. I definitely gotta tie those things down, I don't like having things not properly secured, ya know? Again, I appreciate your efforts too.
Member # 1969
