Author Topic: Vibration From Rear-End At 70 MPH?  (Read 2020 times)
Justin
« on: July 04, 2005, 10:11:30 PM »
Hello everyone,
A little while back, I mentioned the '75 CB400F I've been fixing up, and this past weekend, I finally had the opportunity to take it out to an extended spin!
The only issue I had at all on the trip was a vibration originating from the rear-end at 70mph+...looking down, the rear tire/wheel seemed to almost "hop" or vibrate up and down along the pavement at a high rate of speed...as if there were tons of little bumps on the highway...
What would cause this?
Anyway to fix it?
Thanks.
« Last Edit: July 04, 2005, 10:45:05 PM by Justin »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Vibration From Rear-End At 70 MPH?
« Reply #1 on: July 04, 2005, 10:35:42 PM »
Did you have a burrito for lunch?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
« Reply #2 on: July 04, 2005, 11:43:32 PM »
Anyway to fix it?
Wheel/ tire balance,
worn shocks,
Tire not seated properly on rim,
or all the above.
Ben
« Reply #3 on: July 05, 2005, 02:57:55 PM »
Spokes out of adjustment?
Offline mrbreeze
  • Not your average
« Reply #4 on: July 05, 2005, 10:43:27 PM »
Also be sure to check swing arm bushings.I just got my bike going...(well,almost!) and as soon as I get to hiway speed,I get a bit of wobble back there. I put it on centerstand and checked for play. There it was bigger than #$%*. The swingarm is loose at the shaft.I will be shopping for new bushings later this week.
MEMBER # 257
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #5 on: July 06, 2005, 02:43:20 AM »
A severe tight spot in the chain could also cause problems.
In the UK anything over 40 years old only needs insurance and Fuel.
