Author Topic: where to get some oddball pieces  (Read 1742 times)
playinsafe44
« on: July 16, 2007, 03:28:40 PM »
im in the middle of rebuilding some cb500 carbs (627B) and i was wondering where to get the little felt type of seals that go on the choke shaft, and also where to get the o-rings that go on the fuel T's. there are 8 o-rings that are the same size.
tbone
Re: where to get some oddball pieces
« Reply #1 on: July 16, 2007, 04:05:18 PM »
playinsafe44
« Reply #2 on: July 16, 2007, 09:23:06 PM »
i just looked at that site you posted, and its very helpful and i will use it in the future. but the o-rings look like they are only included in a gasket kit that is about 10 bucks, and it says 4 are required. i already have the carb rebuild kits. i was just wondering if anyone else has ran into this problem and what they did to fix it.
Steelo
« Reply #3 on: July 16, 2007, 10:07:18 PM »
I found some very attractive pink felt and cut some with a set of hole punches. Now dust has turned the pink to a sensitive new age pink brown!
playinsafe44
« Reply #4 on: July 16, 2007, 10:09:13 PM »
haha so you did use just some standard felt, cut it to fit, and have had no problems? if so that sounds like a great fix. (cheap) now all im really worried about is getting these o-rings.
« Reply #5 on: July 16, 2007, 10:24:07 PM »
"O" ring part number 16173-044-004 size 7.8 x 1.9 (mm). felt seal was never available seperate from complete carb
playinsafe44
« Reply #6 on: July 16, 2007, 11:16:53 PM »
thanks for the help!
rsvp9146
« Reply #7 on: July 17, 2007, 12:16:22 AM »
FYI, any good auto parts store will have the o rings
I got mine at Schucks
playinsafe44
« Reply #8 on: July 17, 2007, 03:08:56 PM »
im going to a bunch of stores today to try and get those o-rings. but the more i look at that felt choke shaft seal, the more difficult it looks to make. is there a trick to making these? i have one i can use as a copy. its a really thin ring of felt. im sure i can make the outside edge out with scissors, but the inside edge will be the challenge. any suggestions?
Offline merc2dogs
« Reply #9 on: July 17, 2007, 06:27:56 PM »
 Two short chunks of tubing of the right size, sharpen the edge and tap it with a hammer.
 I've got a collection of spent shells and odd chunks of tube for that purpose in the junk drawer.
Ken.
playinsafe44
« Reply #10 on: July 17, 2007, 11:38:28 PM »
yea i ended up going to the crafts store, getting some felt and a cheap leather hole punch set. it didnt really work at all. i just put the carb back together, i think it should be alright without it. (at least i hope so). it does have the plastic washers pushed against the carbs, and its all tight, and when the choke is open it doesnt matter anyways.
