Author Topic: Clubman bars hitting tank  (Read 3296 times)
danjwsu
« on: July 17, 2007, 08:11:58 pm »
I was wondering if anyone elsee had the problem of the clubman bars hitting the tank when turned.  I've got a 74 cb550 and i cant reposition the handle bars without the hittin.  Does anyone make a riser of some sort? :-\
Offline Chris Liston
Re: Clubman bars hitting tank
« Reply #1 on: July 17, 2007, 08:14:14 pm »
goto your local hardware store and buy small 1/8" or 1/4" hose clamp.  Put them around your steering stops on the lower triple tree.  This will give you the needed clearance.  You'll loose just a little turning radius but it won't affect real riding at all.  I've done this with my clip ons and have no issues.
1976 CB550F Cafe in progress
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: July 17, 2007, 08:17:46 pm »
edit:  Chris beat me to it, but I'll post anyway...
One way to resolve that issue is to limit the distance the bars will turn.  Some have drilled and tapped a hole in the steering stop tabs and screwed in a small bolt to keep the bars from turning as far as they normally would.  Others have gone the easier route and just slipped a short piece of rubber hose over the tab to get the same result.
danjwsu
« Reply #3 on: July 18, 2007, 04:11:38 am »
Thanks, I'll give it a try tonight.  Its always the simple things that you never think of.
Offline KB02
« Reply #4 on: July 18, 2007, 05:06:30 am »
That's what I did with mine. One of those screws was a B*tch to get in there though...  ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
