Author Topic: Spring compressor  (Read 1086 times)
Offline mmtsquid
Spring compressor
« on: July 18, 2007, 09:57:07 am »
What kind of spring compressor should I buy to deal with my shocks?  I looked on e-bay, and there are 206 different ones on there.......HELP!!!
77 CB550K4
Offline Tim2005
Offline puppytrax
Re: Spring compressor
« Reply #2 on: July 18, 2007, 02:48:06 pm »
Well, I'm a cheap SOB...and I have a Sears bench vise bolted to my bench...
So I found an old piece of 3" angle iron, cut a 5/8" slot in the middle of it, and bolted it *behind* my vise...
So now I open the vise all the way, put a long bolt in the bottom of the shock and butt it against the end of the movable jaw and fit the angle iron between two coils and crank the vise in...and remove the shock clips and take the spring off...
I have done a bit of "customizing" to my angle iron...cleaned it up, bent the sides to match the angle of the coils, etc...
Cheap, effective, and simple...   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline kghost
« Reply #3 on: July 18, 2007, 02:50:59 pm »
I'm even cheaper than you......
I use 6 zip ties tightened incrementally  ;D
Stranger in a strange land
