SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Compression Check, No Carbs
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Compression Check, No Carbs (Read 1057 times)
B. Alec
Guest
on:
July 18, 2007, 05:53:42 pm »
I know you check compression with the throttle open. Could someone confirm my suspicion that doing a check with the carbs off the bike is the same thing as doing it with wide-open-throttle? I got low numbers on my barnyard 75 550, and just want to be sure they mean what I think they mean:
Cyl 1 - 105
Cyl 2 - 100
Cyl 3 - 70
Cyl 4 - 95
Thanks!
Logged
eurban
Master
Re: Compression Check, No Carbs
Reply #1 on:
July 18, 2007, 06:25:24 pm »
Compression numbers will be at least as high with no carbs as they will with carbs on and WOT. . . . .
Logged
B. Alec
Guest
Reply #2 on:
July 18, 2007, 06:33:35 pm »
Thanks! So, given the low numbers and the difference between cylinders, I'm definitely looking at a rebuild, but is a re-bore probably necessary, too? What are some of the things I should look for to figure out if I need to go that far?
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
