Author Topic: Hagon vs. Progressive shocks  (Read 2558 times)
Offline david 750f
  • 1976 CB750F
« on: July 19, 2007, 11:19:13 AM »
Anyone have any thoughts/recommendations on which rear shock to go with??
Thx
1976 CB 750F
RSV12K
Re: Hagon vs. Progressive shocks
« Reply #1 on: July 19, 2007, 12:10:23 PM »
I've had both of them. The only real difference I can think of is that you have more spring options with the Hagons. If you're on the porky side, maybe 210 lbs or better, or if you like a stiff ride, the Hagons are a better bet. I don't have the Progressives to compare with the Hagons I currently have but I believe the Progressives had better fit and finish (setting the preload seemed smoother or easier). Again, I'm fuzzy on it, but I think the Progressives also had one more preload setting. You can get a standard or a heavy duty spring with the Progressive 412s. I weigh 210 lb and found the heavy duty just fine. I'm always been happy with Progressive's stuff and wouldn't hesitate to recommend it.
Price is about the same.
Overall, I would go with the Hagons, mainly because the people who sell them: www.davequinn.com know what they're talking about and can tell you what spring is going to be right for you and if it isn't, will let you swap it, no springs attached (wasn't that punny?).
Offline martini
« Reply #2 on: July 19, 2007, 01:54:59 PM »
I agree with the comments above re: Hagons. When I ordered mine they were very good about making sure I got what I needed and I've been more than happy with them.
Rocking-M
« Reply #3 on: July 19, 2007, 02:45:33 PM »
Hey, I can't get the link to work, hep! HEP!!!!
RSV12K
« Reply #4 on: July 19, 2007, 03:15:50 PM »
Sorry, iInstead of guessing, I should have Googled it: http://www.davequinnmotorcycles.com/cgi-bin/webc/home.html
Rocking-M
« Reply #5 on: July 19, 2007, 05:33:32 PM »
Thanks RSV, that one worked ;)
