Author Topic: Please help on this CB750K (even though it is a DOHC)  (Read 3129 times)
CBR_Rod
« on: July 19, 2007, 01:10:30 PM »
My father-in-law bought a 79 CB750K,  Pretty clean, all original, 12K on the clock.  We went for a ride the other night and as I let him pull up to me so I could tell him how dim his headlight was, the bike died.  We push started it, and that nearly got him home that night, but a second push start would not immediately start the bike, he had to wait a few minutes I guess.
Anyways, I searched the forum for info on testing the Stator and found that apparently I needed to check voltage on the 3 yellow wires coming off the stator.  Well, we just got through checking them, at the point where they go in to the regulator/rectifier and all 3 would read 14 to 15 volts (checked on the AC side) at idle and would get upwards of 22 to 23 volts at 5 grand.  Near as I can tell that is about half what it should be putting out.
I checked the 3 wires against a frame ground and the black wire ground as well, the above readings were from the frame.  When checking with the black wire I'd get less than a volt like .6 to .8 volt.
Does this sound like a failed stator?
One other question, what is the white wire that ran grouped together with the 3 yellows and 1 black wire?
He charged the battery to get the bike going.  When I checked the batery it was just over 12.0 volts with ignition off.  When it was running, it registered 11.2 volts at idle and 11.5 at about 5,000 RPM.
All help appreciated.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
Re: Please help on this CB750K (even though it is a DOHC)
« Reply #1 on: July 19, 2007, 01:15:15 PM »
The first thing I would try would be a "known" good battery, and see if you get higher voltage readings while running.
–Captain Horatio Hornblower
www.thehairynickel.com
CBR_Rod
« Reply #2 on: July 19, 2007, 02:12:06 PM »
What would a new battery have to do with the stator output?  Can it draw a stator dow or something?
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #3 on: July 19, 2007, 02:27:07 PM »
I just mentioned that as a quick and cheap way to start the troubleshooting process. God only knows where the electrical glitch is, but you'll feel kinda silly if you go to the trouble of replacing the stator only to find out that it was just a worn out battery the whole time.  ;)
CBR_Rod
« Reply #4 on: July 19, 2007, 02:54:35 PM »
OK, thanks, but from what I've dealt with in the past, a good charging system will sustain the ignition system and lights and keep the motor running, with or without a low battery.
As it stands now, the battery gets charged up (with a battery charger) and the bike starts and runs fine until the electrical system drains the battery by one of two means, either a stator not putting out enough volts to sustain the system and charge the battery or the regulator rectifier is bad.  I'm wanting someone that is in the know with stator testing to verify if I have checked out the stator sufficiently or not and if I have do they concur that the stator is bad or am I missing something.
As for the Battery condition, it is approx. 6 months old and according to my charger with built in tester, when charged, it indicates the battery is good when load tested.
Offline 82CB650SC
« Reply #5 on: July 19, 2007, 03:15:31 PM »
check the rotor resistance should be about 4 - 6 ohms.  it uses the same rotor as the 650s and they are known to short
Bob  1982 CB650SC
Never force it just use a bigger hammer
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #6 on: July 19, 2007, 04:24:30 PM »
I'm not going to pretend to be an electrical guru...far from it...but if you do a forum search you'll find that these early Honda charging systems operate differently than you're used to; a low battery will in fact affect how the bike runs, regardless of the state of the charging system. More informed members than me can fill you in as to why.
CBR_Rod
« Reply #7 on: July 19, 2007, 06:38:54 PM »
Could you tell me how I should test the rotor, i.e. wires (yellow and black), pull stator cover and check something in there?
Offline tsp37
  • I don't want a pickle . . .
« Reply #8 on: July 19, 2007, 07:37:16 PM »
This was a good trouble-shooting guide for me:
http://www.electrosport.com/electrosport_fault_finding.html
« Reply #9 on: July 19, 2007, 08:02:46 PM »
Brushes and/or rotors go bad way more often than stators and without a decent battery voltage/current into the rotor you will not geta decent stator output, which should be over 20 volts AC between yellow conductors if disconnected
CBR_Rod
« Reply #10 on: July 19, 2007, 08:45:40 PM »
Thank you, this looks to be very helpful.
CBR_Rod
« Reply #11 on: July 27, 2007, 05:23:10 PM »
Using that intuitive guide in the provided link I finally got around to checking out the in-laws CB750K (79 model).  According to the flow chart, the Rotor is bad.  I got to where it wanted me to check the resitance between the two slips rings (I assumed these were the two places the brushes ride on the rotor?).  The book said there should be between 4 and 6 Ohms resitance.  There was no resistance.  I checked continuity between the wire plug and the brushes and it was good.
Can anyone suggest where to buy a new Rotor for this bike?  As I understand it the Rotor is interchangable between the 79-82 CB650, CB750, CB900, and the CB1100.
Thank you for all the help.
Offline jmuthaf
« Reply #12 on: July 27, 2007, 07:29:23 PM »
 Yeah, i have an 81 dohc with the same problem. The rotors are usualy the suspect for not charging on these bikes. I had my rotor rewound by a guy on ebay, http://cgi.ebay.com/ebaymotors/Rebuilt-Honda-cb-650-750-900-1000-1100-rotor_W0QQcmdZViewItemQQcategoryZ35594QQihZ008QQitemZ180143258836QQrdZ1QQsspagenameZWDVW he uses better wire, and a better epoxy to seal it.
Offline jmuthaf
« Reply #13 on: July 27, 2007, 07:32:58 PM »
PS -  getting the rotor off can be a pain, it is a pressed on taper fit. you can use the rear axle, it is the same thread size, thread it in and smack it with a hammer a few times, tighten it, smack it tighten it... and it'll pop off.
CBR_Rod
« Reply #14 on: July 27, 2007, 07:51:08 PM »
Thanks for the link and recommendation.  I forwarded the link to my father-in-law.
CBR_Rod
« Reply #15 on: August 06, 2007, 11:25:04 AM »
Well, here is what is happening so far.  Some sneaky fellow jumped at that provided link on Ebay and it was sold by the time my father-in-law found it.
Anyways, that same seller has prepaid auctions where my father-in-law is sending in his Rotor to be rebuilt.  In the mean time I order him new tubes and tires for his bike and this give us time to change them.
