Author Topic: WHAT YR. EXHAUST  (Read 1884 times)
alexsir00
WHAT YR. EXHAUST
« on: July 05, 2005, 05:02:59 PM »
had a quick question....
which years exhaust will fit on a 75 cb750four k5?i think.... ???
alexsir00
Re: WHAT YR. EXHAUST
« Reply #1 on: July 06, 2005, 05:30:48 PM »
hmmmm no one ehh.... :o
Offline MikeDeB
« Reply #2 on: July 06, 2005, 05:52:46 PM »
1969 through 1976 will fit a K5.  HM300s for 1969 through 1971 and HM341s for 1972 through 1976.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
alexsir00
« Reply #3 on: July 07, 2005, 03:49:16 PM »
HMMMM interesting thanks. ;D
but ummm what does the HM's mean? ???
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: July 07, 2005, 04:30:02 PM »
HM=Honda MotorsĀ  ;)
Offline Jonesy
  • Shop Rat
« Reply #5 on: July 07, 2005, 04:41:40 PM »
HMC=Honda Motor Code. 300=CB750 K0-K2, 341=K3,K4,K5 (American Models)
alexsir00
« Reply #6 on: July 07, 2005, 06:15:26 PM »
oooo.....i see.....
i know im buggin everyone but what the difference between a cb750F and cb750K?
Thanks again
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #7 on: July 08, 2005, 02:00:47 AM »
The K comes with 4-4 pipes as STD but the F series all have 4-1's.
The 4-4 pipes have a different fitting arraingement at the head, these can be fitted to either series but you need the whole assembly.
The K has spigots that bolt to the head then the header pipe slips over this and is held in place by a clamp that pinches the header pipe.
The F series has a flange on the end of the header wich is pushed into the head by split collars held in place by the large round clamp.
Supperficialy they look very simmilar, if you look at the large clamp arround the header, the one with the cooling fins in it, you will see the K one is split on one side with a pinch bolt, the F will have 2 studs holdong it directly to the head.
Most K's that have 4-1 fitted now have the F style monting used as this has become fairly standard on just about all bikes these days.
In the UK anything over 40 years old only needs insurance and Fuel.
