It's not a lubricated part or part of the oil sump, in fact the engine has a dry sump so oil level won't reach the alternator which sits about an inch higher. You'll find oil in there because there's no seal on that end of the crankshaft, but nothing major.
You risk however leaking oil into the rear tire track or path, so if you worry about this try sealing it with epoxy to get to the repair shop.
