Hiya, just a few other common things I'd suggest you check out... rust in seat base & front lower corners of fuel tank, mileometers which don't work, camchain tensioner adjusting bolt stripped or broken off (very common & a PITA), excessive smoking from breather when hot (top rings gone), broken kickstart lever, 6th gear gone, cracked sidepanels (esp. r/h), cracked front indicator mounting tube. Otherwise, they're a pretty strong little bike, they like to be serviced regularly (oil change, timing & camchain tension every 1500) & I like to think they need to be ridden hard! Keep the revs in the 6-8500 range & they're a lot of fun.
Cheers
