Author Topic: can someone post a pic of...  (Read 2150 times)
Offline galaxian
« on: July 06, 2005, 06:11:52 AM »
Can someone post a pic of how to mount the front caliper and bracket on a cb750k3? I am not sure if i am missing parts or not and the maual shows a different bracket from mine.
1973 cb750k
Offline kghost
Re: can someone post a pic of...
« Reply #1 on: July 06, 2005, 06:53:17 AM »
If memory serves the "parts" are the same some just have a different shape.
That is to say the number of parts are the same and they do the same jobs. The basic shape on a couple parts changed a bit.
For example the pivot that bolts to the fork leg and the lever that is on it (the one the caliper bolts to), changed in final shape. Still goes were the one in the pic does and still does the same thing just looks slightly different.
Stranger in a strange land
Offline 6pkrunner
« Reply #2 on: July 06, 2005, 07:29:51 AM »
The K3 changed the way it mounts to the forks. It uses a "T" shaped pivot with two bolts at the top and one at the bottom. The fender mount also changed to accomadate the switch.
The first picture is of the K2 down mount.
and this second one is of the K3 up mount.
Offline galaxian
« Reply #3 on: July 06, 2005, 08:46:48 AM »
Thanks but what I really need is how they mount to the fork and the orientation of the bracket.
1973 cb750k
Offline galaxian
« Reply #4 on: July 06, 2005, 11:59:14 AM »
Ok how about a close up pic from both sides of the bike so I could see the bracket from both sides...pretty please ;)
1973 cb750k
Offline cben750f0
« Reply #5 on: July 06, 2005, 06:33:13 PM »
ok these pics are of the double disc set up, but you might get an idea of the way it. goes if not i will have to go out and get some better pics... let me know... cheers
« Last Edit: September 07, 2007, 05:12:01 AM by Glenn Stauffer »
Offline galaxian
« Reply #6 on: July 07, 2005, 05:49:49 AM »
Thanks!! That exactly what i needed!! ;D
1973 cb750k
