Author Topic: Don't Let Those Carbs Sit! (With Visual Aids)  (Read 2804 times)
B. Alec
« on: July 23, 2007, 06:13:35 PM »
Pulled and dipped a carb off my free '75 550 this week. These were left on the bike outside in Minnesota from '98 to '05. Some before-and-afters for your viewing pleasure:
Looks like I may be parting this bike out after all rather than trying a full restore.  Unless anyone has a magic carb restoration idea? The rest of it isn't much better.
The good news is that carb dip works great!
Offline puppytrax
Re: Don't Let Those Carbs Sit! (With Visual Aids)
« Reply #1 on: July 23, 2007, 06:20:39 PM »
*Which* carb dip??  Everybody here has a favorite..."Tastes Great!"..."Less Filling!"...   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
B. Alec
« Reply #2 on: July 23, 2007, 06:30:51 PM »
Ah, yes, since the wonders of capitalism only gave me one choice at my local auto parts store :-[, I didn't have to think too hard about brand preference.  It's Solder Seal "Gunk" Carb Cleaner in a paint can.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #3 on: July 23, 2007, 06:48:16 PM »
Mine were quite chewed like that, so I JB welded my jets in.  Since they were essentially shot, I figured what's the worst that could happen.  Basically just keep the form of what was originally there so it all goes back together(in other words, don't just slop it on).
Yeah it's redneck, but read all the uses on the JB weld package and you'll feel alot better about it.
1977 CB750
Offline 333
  • Time for change
« Reply #4 on: July 23, 2007, 06:56:54 PM »
I recently saw a thread about using a 50/05 mix of Simple green/water (with photos) that looks like a winner.  I think it was Bob Wessner
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline puppytrax
« Reply #5 on: July 23, 2007, 07:10:03 PM »
What's the other 45%??
Offline Loudpipe
  • Broken Vehicle Collector
« Reply #6 on: July 23, 2007, 07:12:42 PM »
As for a good carb cleaner, go check your local autoparts store.  I have never used it this way...maybe somebody has, but Purple Power is a biodegradeable degreaser/cleaner, and seems like it would work well on a dirty old carb.  It works well on just about every other part of the bike i've tried it on.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline 333
  • Time for change
« Reply #7 on: July 23, 2007, 07:14:29 PM »
Sorry, finger slipped  50/50
Offline Bodi
« Reply #8 on: July 23, 2007, 08:41:40 PM »
It looks OK to me. The main jet and float valve have O-rings, and the inside of the main jet hole looks clean enough to seal. Both posts are strong enough to hold a float. Not pretty, but I think it would work fine.
Offline Frrrrunkis
  • Southern Fried Pest
« Reply #9 on: July 24, 2007, 10:27:25 AM »
I had a post broken off in carb #1, drilled it out and put a pin in there, and JB welded it back on. Definitely was a problem that when once fixed, you're obsessive over making sure the petcock is closed. I used a $2.50 can of gumout to clean mine up, worked pretty well.
1975 CB400F - "Ol' Red"
Opie & Anthony - Spread the Virus!
my bike pics - http://www.flickr.com/photos/10057704@N05
or http://www.bikepics.com/members/frrrrrrunkis/
If it appears that I don't know what I'm talking about or doing in this post, I more than likely don't
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #10 on: July 24, 2007, 11:53:32 AM »
I second Bodi's observation.  As long as the main jet seals and all other passages are clear, "everything will be just fine". (Doc. Brown).
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
B. Alec
« Reply #11 on: July 24, 2007, 02:35:28 PM »
Sweet!  Thanks, y'all.  Now on to the parts in even worse shape.
Offline puppytrax
« Reply #12 on: July 24, 2007, 02:43:41 PM »
Wait!!! Don't go away!!!   :o
Did you cut the Gunk 50% with water, or use it full strength?? Did you heat it to just under a boil, and then let it soak overnight??
Inquiring minds want to know...   ;D
B. Alec
« Reply #13 on: July 24, 2007, 03:13:00 PM »
No dilution, straight in without boiling, and left the main body in overnight.  I didn't even really have a brush to use on it [I do now!], so the pictures there are the result from just rinsing it off.
