Author Topic: Keyster Carb Rebuild Kit for Honda CB750 1978  (Read 4261 times)
obnoxshuz
« on: July 24, 2007, 09:44:36 PM »
I just ordered 4 sets of the Keyster Carb Rebuild Kit for my 78 cb750 from Sirius Consolidated.
THEN, I thought of doing a search on the keyster kit here in this forum.
Please, tell me I didn't just make a $99.00 mistake ordering this kit ?!!
If so, how can I salvage my purchase ? Is there a particular part that I SHOULD NOT USE ?
Is it just the needle with a different taper that I can't user but all the other parts are ok ?
I think I remember Medic mentioning using this kit on his 78 750K...
Thank you for your help
Angelo
luvhonda750
Re: Keyster Carb Rebuild Kit for Honda CB750 1978
« Reply #1 on: July 25, 2007, 07:28:46 AM »
I used the same kit on mine, It worked good with the exception of the float bowl gaskets, I think it might be better to keep the original ones if they still have a good seal. Just make sure the main jets are the same size as your old ones.
Offline lucky
« Reply #2 on: November 09, 2011, 02:08:11 PM »
No need to change float bowl gaskets unless they were leaking.
You will cause yourself MORE problems.
Offline Bob3050
« Reply #3 on: November 09, 2011, 02:17:55 PM »
Lucky:
    How did you come to respond to a four year old thread?
Bob
« Reply #4 on: November 10, 2011, 01:39:28 AM »
hes bored,,an old thread but the brass main jets can be wrong,ive checked a few and the stock kiehin #100 will just gently pass a 1 mm drill bit,,on the keyster #100 the same drill bit floats through much easier=rich, at least on my batch,use the factory jet needles unless they have an obvious worn flat on the taper,,use a magnifying glass,it might be too late,april24/2010 was obnoxs last post.
« Last Edit: November 10, 2011, 01:47:32 AM by dave500 »
