Author Topic: my CB550 build thread....finally back to work on it  (Read 38560 times)
Offline forwheeldrift
  • 1972 cb 500 Four
    • pics
Re: my CB550 build thread.... almost done
« Reply #75 on: January 24, 2008, 10:46:47 AM »
sweet ride
Offline greenjeans
  • 1972 CB750K2
« Reply #76 on: February 12, 2008, 05:34:58 PM »
Man...... you nailed that color.   Looks awesome.
I really like the look of the seat pan, how's it feel ?  Comfortable ?
rlarkin70
« Reply #77 on: February 12, 2008, 09:31:00 PM »
That thing is so sweet, it just doesn't look right sitting still...
-Ron
Offline rachet
  • '77 CB750 F2
« Reply #78 on: March 13, 2008, 12:06:30 PM »
Now that we have a "Project Shop" board I rediscovered this build and would love an update and some pics~  I know you were moving so have you had a chance to get back to it?
anyways, Great Build! one of my favorites!
Rachet~
But I need Tacos!  I need them or I will explode!
Offline DarkRider
« Reply #79 on: March 13, 2008, 10:58:42 PM »
i must say i like the way you did the rearsets...any chance you could build a couple more of those mounts? Or at least send me a diagram of the measurements?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #80 on: March 13, 2008, 11:14:52 PM »
It's time we had an update 91, yavent posted since January ;)
Sam. ;)
fixahonda
« Reply #81 on: March 16, 2008, 10:32:05 AM »
That is an excellent looking bike there. I'm not all that big on the cafe look but I love the way that is turning out. It was said above, but some things just look right and yours is definitely one of those.
Offline c91x
« Reply #82 on: March 18, 2008, 11:02:45 AM »
I wish i had an update for you guys and myself but the cb has been put on the back burner till i get settled in and buy a house or at least rent one... I have to go to oklahoma for some FAA school for a month and then when i get back to phoenix i'll start in on it again. it probably needs another 5hrs of work to be close to finished but i needed to finish my other truck before i left so it got the attention
once again thanks for all the compliments on the bike
Offline squirley
« Reply #83 on: March 18, 2008, 10:07:26 PM »
Maybe I missed it in the thread, but where did you get your hands on that rear brake light?
Offline c91x
« Reply #84 on: March 19, 2008, 02:14:20 AM »
5 bucks at walmart... it's a trailer light
darkrider i sent you a pm
« Last Edit: March 19, 2008, 02:19:26 AM by c91x »
Offline A Grove
  • Some people call me a
« Reply #85 on: July 02, 2008, 08:14:55 PM »
I know this thing is old... But do you have any more pics of this beast?! She's absolutely gorgeous!!
SSCR
« Reply #86 on: July 03, 2008, 07:54:19 AM »
Just saw this thread great work! Any more info you can spare on where you got that awesome tank?
Offline j-conn
  • Federico Fabrizi
« Reply #87 on: November 13, 2009, 01:33:14 PM »
looks awesome!!!
1976 CB550
Member #7772
Offline c91x
« Reply #88 on: November 13, 2009, 03:36:01 PM »
it's sad to say but this bike hasn't been touched in over a year. i got it going took it in for emissions and it failed and i lost interest and time and started new projects.
in the last year a dirtbike rim fell on the tank leaving a dent, my nephew dropped the seat and put a chip in it, the front caliper started leaking, and hmm what else. i started lurking on the site again and i've got it up and going again.. finished my shorty exhaust and extended the center stand so it actually holds the rear tire off the ground... the stator gets really hot if i turn the ignition on even without the bike running. i've checked the wiring twice and its fine and no wires are getting hot just the stator cover. The idle is sporadic and i figure maybe an air leak somewhere but i never did get the jetting figured out before so that might be some of it
« Reply #89 on: November 13, 2009, 03:47:46 PM »
Surely they don't expect a 40 year old bike to meet modern emission standards, if this were the case there would be nothing over 10 years old on the road.
Offline c91x
Re: my CB550 build thread....finally back to work on it
« Reply #90 on: November 19, 2009, 04:09:51 PM »
lookin for anybodies two cents
Ok so my problem is i've been messing around with jetting and finally got the right main jet in but when i went from a 105 to a 115 something happened with my idle. When i give it gas it takes forever to come down from 3000 rpms to idle and the idle is sporatic and needs adjustment sometimes . if i turn the idle screw down it will  drop off revs  like normal and drop back to 1000rpm before it dies after a few seconds sound crisp and clean when i do this. the bike idled fine before but was running lean. No air leaks from the test i've done. i'm thinkin i need to drop a notch on the needle jet. pleas help !!!!!
Offline c91x
« Reply #91 on: November 19, 2009, 06:34:43 PM »
« Last Edit: November 19, 2009, 06:37:01 PM by c91x »
bmarshall
« Reply #92 on: November 21, 2009, 04:32:12 AM »
From what I understand an idle hang-up can be caused by a lean condition, if your bike has been sitting for a while the pilot jets may be clogged causing this.
Offline Flying J
« Reply #93 on: November 22, 2009, 10:36:12 PM »
What carbs are you running? Where did you get your v-stacks?
Offline c91x
« Reply #94 on: November 23, 2009, 04:47:44 PM »
I'm with ya but it doesnt' make sence that when i turn the idle screw way down it drops off rpms quick and crisp... i'm gonna take them apart and give htem a once over.. also make sure the needle jet is seating properly on the main jets
Offline c91x
« Reply #95 on: November 23, 2009, 04:48:31 PM »
stock carbs! velocity stacks i got off ebay over a year ago.. pretty sure same guy sells them still
Offline chronic_rider_550
Re: my CB550 build thread....new pics
« Reply #96 on: March 22, 2010, 01:12:10 PM »
anybody got some ideas for paint scheme and color ?????  . i've got a few ideas but nothing that i'm really into. also license plate location i really don't want to see this thing but i think i'll mount it under seat in front of the tire not to clearly visible but i don't want to ruin the look with the plate on the back
Not sure if you have figured out where you license plate should go but you should check out my build and look at the license plate. It is half hidden but you can still see it and it doubles up as a rear fender. Just an idea.
http://forums.sohc4.net/index.php?topic=67122.0
"Faster, faster, faster, until the thrill of speed overcomes the fear of death."  ~Hunter Thompson
A friend is someone who'll get out of bed at 2 am to drive his pickup to the middle of nowhere to get you when you're broken down.
Offline Raef
« Reply #97 on: May 24, 2010, 09:12:03 AM »
I have had similar problems with my custom exhaust and pods the latest dilemma is getting the engine to take gas mid to low rpm,it runs like a race bike on top end just not road friendly. one of the conclusions I have came to is that the stock carbs need more than just air flow they need some vacuum or negative pressure to draw fuel from the bowl.
When I regain enough energy to try it again I think I will be looking for a later model carb set up with a accelerator pump and possibly a fuel pump
Offline c91x
« Reply #98 on: November 07, 2010, 08:27:32 AM »
i have to many hobbies! I can't believe it's been another year since i've worked on it... well i finally ordered  some new main jets and i'm gonna move the needle down one clip. i've got a new voltage regulator and rectifier i need to put in. then sync the carbs get emissions on it and ride it.
Offline CB550CAFE
« Reply #99 on: November 07, 2010, 09:55:40 AM »
Just read through your thread 91, this CB is smokin' nice! I love the tank and seat. Look forward to the updates!
-Derek - 1976 CB550
