Author Topic: Throttle issues on a 76 cb550k  (Read 1594 times)
Offline Badger 5
    • Gallery
« on: July 29, 2007, 12:05:19 PM »
Spent the day in the garage yesterday and got everything done that I set out to do!  I don't know about the rest of you but that very rarely happens with me.  After I got new tires on and my front caliper rebuilt I took the bike out and the longer I rode the bike I noticed the idle kept creeping higher.  After further inspection I found that it wasn't the idle but my throttle that was the issue.  If i twist the throttle the opposite way it brings it back down.  I'm not sure if the problem is the throttle cables or on the top of the carbs.  Question:  where is the best place to start.  I checked the FAQ but couldn't find a throttle thread.  Thanks in advance for the advice.
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Offline OldSchool_IsCool
  • Really feeling like an
Re: Throttle issues on a 76 cb550k
« Reply #1 on: July 29, 2007, 12:34:57 PM »
Divide and conquer.
Disconnect the cables from the carbs, do the cables move freely?
Does the throttle grip move smoothly?
Does the throttle bar on top of the carbs also move freely?
Does the return spring do it's job?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Badger 5
    • Gallery
« Reply #2 on: July 29, 2007, 12:44:45 PM »
I know how to adjust and lube or even change the throttle cables but, if it's the throttle bar or the return spring what is the solution?
76 CB550K
75 CB200T
75 XS650
Offline Bodi
« Reply #3 on: July 29, 2007, 01:24:32 PM »
About all you can do with the throttle assembly is oil the "bearings" the rod turns in. Lube both cables - just dribbling oil in the top end and working them a bit should do it, you can get pressure lubricating thingies but I've never tried one. Then make sure there's plenty of slack in the cables, you can tighten them up too much and the whole cable and handgrip system gets very hard to move. The slack changes from left steering lock to right, so make sure it's OK both ways. If the cable routing is wrong you get too much friction too.
Offline Badger 5
    • Gallery
« Reply #4 on: July 29, 2007, 04:34:02 PM »
What should I use for this?
76 CB550K
75 CB200T
75 XS650
Offline dusterdude
« Reply #5 on: July 30, 2007, 10:38:20 AM »
make sure your throttle sleeve on the handlebars is nice and lubed too.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Badger 5
    • Gallery
« Reply #6 on: July 30, 2007, 07:49:39 PM »
Divide and conquer.
Did all this and I still have the same issue.  I'm not sure how to explain this but carbs one and two are solid but three and four are kind of mushy when I push down on the hex nuts.  the idle goes up to almost 3000 and the idle adjust screw is all the way out.  When I push down on the hex nuts the idle goes down to where I want it but I'm not sure how to get it adjusted down to where I want it.
76 CB550K
75 CB200T
75 XS650
« Reply #7 on: July 30, 2007, 10:37:01 PM »
have you vacuum synchronized the carbs?
Offline Badger 5
    • Gallery
« Reply #8 on: July 31, 2007, 03:34:36 AM »
I am going to do it tomorrow.  It's the last thing i can do before I pull my hair out. >:(
76 CB550K
75 CB200T
75 XS650
