Author Topic: I'm new, I need project and general maintenance advice. Bear with me.  (Read 4493 times)
Offline turin39789
I have a 75 550f, it was sold as a 74 but the title says 75.  It runs fine, except for a few issues and I'm getting ready to start to learn this bike a little better.  This is my first bike, I've had it for about two months and I've been riding it for a month and a half.  ~10,000 miles on the bike.  It came with an untitled parts bike that he bought from ebay, which has already donated a front brake caliper(I managed to strip the threads on the brake line connection on the original one), as well as a headlight assembly.
The bike was running when I bought it, the front brake was seized, but a simple disassembly and cleaning fixed that up(there seemed to be little salt like crystals in the cylinder) the pads hadn't passed the red wear line, but I still need to bleed the brakes and clean up the rear to get them working good.  I had to ride home in the rain once and lost a great deal of my braking power, very scary.  I've had one scary fall already, coming around a turn and a van slammed on their brakes in front of me to make a turn without signalling.  I can't say for sure if it was the brakes fault or if I wasn't paying attention and didn't react soon enough.  I saw the van, grabbed the brakes and the next thing I knew I was sliding down a driveway off to the right, so maybe the brakes locked, maybe I tried to turn and brake at the same time.  Helmet and jacket left me with just scuffed hands and a scuffed knee, nothing worse than what I got riding a bicycle as a kid.  My passenger just rode on my bike and never touched the ground.  We got lucky, and I got scared and now I want to give the bike a good going over.
I also need to go ahead and do my first oil change, probably wouldn't hurt to do the trannsmisison fluid as well.  I'm going to go back into the oil section and pick my oils and try to work this out.  I tried to get the bike up on the center stand, but it was fairly difficult, so I'm going to try again and just pull harder but I might need to oil something up.
The electrical system is a little messed up.  It had a windjammer fairing that was wrecked when the po laid the bike down last fall.  I removed that, and I have the front headlight working and the rear brake light, but no turn signals or front brake light.  I use both brakes at every stop to make sure I stop and light up.  I'd like to get this all working, and I'm also afraid I either have a short or a weak charging system.  I left my key in the ignition last night turned on, and this drains my battery completely.  I jump started and rode to work(15 minutes with about 7 on the highway) and it stalled at the next stoplight and would'nt start.  I'm going to need a jump to get home, as I have tried in the past to pop the clutch and it won't get going.  The electric start was working fine when I got the bike, but now it just makes some noise and doesn't turn the engine.  Oh well, Kick starting is fun.
She leaks gas.  I learned quickly to make sure the petcock is shutoff or I'd leave an expensive puddle.  It leaks slightly from one of the hoses going into the petcock, and also from the hoses going horizontally into the carbs.  I'm not sitting by the bike or the manual so pardon my technical descriptions.  I'd like to get this cleaned up, but I found out when trying to rebuild my carb on my car(72 VW beetle) that I'm not that great with carbs.  I'm young(25) and I teach myself mechanics as I go, I've gotten decent with a wrench on the car, but I'm hesitant to start tearing this thing apart because I like to ride it every day to work.  I need to track it better, shutting off the petcock does pretty good but I think after a hard run on the highway she'll leak some no matter what.  I stopped by a shop and he quoted me $20 for new gaskets and floats, and about $300 for labor.  I might have to tackle this myself.
I get a clicking/knocking noise that I don't like at low rpm's/idle.  If you put your finger on the spark plug cap furthest out on the left leg side, you can feel a tap to coincide with every noise.  I'm hoping this isn't too expensive a sound and I'll just have to adjust the valves, but I'm thinking I need to take the tank off to do that and again, I'm new and hesitant.
I need new tires.  I think.  The ones on the bike have cracking, but good tread.  The PO said he meant to replace them but never did, and I've started to do the same thing.  I know with tubes the cracking isn't as big of a deal as a tubless, but for safeties sake I should go ahead and get them changed.
I imagine this is probably just a long and annoying rambly post, but I really want to start cleaning up the bike and getting her safer and running better.  I figure even if I annoy you by asking simple questions it'll get me started.
Offline turin39789
That's the quick post I managed to blurt out on my break at work.  I'm basically looking for advice on what to tackle first, and how to do some of it.  What is the checklist for items to address with any bike of this age after purchase, and I'll probably need some help doing them.  I;m in Lexington Ky, and travel routinely to Louisville so if you know of any shops or members in the area to recommend, I'm listening.
Here are pictures from the seller before I bought the bikes, I will try to get some current ones in the next few days.  Let me know if you want any specific pictures.
Here's my bike, the fairing is off and I mounted some old hard Bates saddlebags that came with the bike, I had to rig it up a bit, but they fit and lock and are very convenient.  The engine is beginning to turn a bit brown/orange from burnt spilled gas.
Shot at 2007-06-07
Here's the parts bike, I've got a tank for it and the exhaust is rusted through
Shot at 2007-06-07
And here's a third bike that came with the lot, also no title and hasn't ran in years, he intended it as a project but never got to it.  I'm thinking about trying to go through the bill of sale hassle to get a title, but I might just part this guy out.
Shot at 2007-06-07
« Last Edit: July 30, 2007, 08:11:30 AM by turin39789 »
jdigga
Welcome to the forum and congrats on a great first bike.  I got my CB last fall and this forum has been the source of knowledge and wisdom.
You've gotten your crash out of the way; glad you two weren't seriously hurt.
A lot of little things can add up to an overall level of roadworthiness; it's definitely in your interest to sort out as much as you can.
I'll see if I can address your questions somewhat:
Engine oil also lubes the transmission (wet clutch also for that matter), so no separate tranny fluid there.
Centerstanding is all about technique--stand on the left side of the bike, LH on the left grip, RH on the grab bar, RF on the centerstand peg.  Lock out your right arm and bend your legs.  Drive up with your legs instead of trying to pull up the bike.
Electrics are always an issue on these old bikes.  Your lighting problem will most likely be in the headlight, a.k.a. the rat's nets.  There are some great diagrams on oldhondaman.com.  If the turn signals and things worked on the Windjammer, it shouldn't be much to correct it.
These bikes won't run well (or run at all) on a weak battery.  Your charging system might be okay.  Charging occurs above 3,000 RPM and might take a couple hours of riding to fully charge the battery.  Check out the electrics FAQ.
For your carbs, if you're leaking at hoses, then new gaskets and floats don't sound like they would correct the problem.  Carbs are another popular topic here so you'll find plenty of threads on them.
Many of us would agree to tackle them yourself; the more you do yourself, the more you will learn and the better you will know your bike.
These engines are generally noisy, but you should definitely check your valves.  Taking the tank off is the easiest part.
Other things to consider: check air filter, spark plugs, cam chain tensioner, ignition timing.  But again since you're riding your bike daily, the PO probably already sorted this stuff out.  But no harm in checking them for yourself.
You've got plenty to do, but for the most part it's stuff that won't keep you off the road for long.  I'd say tackle one thing at a time, and the good folks here can help you with the details along the way.
BTW, cool 700SC.  It looks pretty complete; might not take much to get it running.
Offline turin39789
Thanks for the response!  I work full time, I'm in school part time, I have irons in a dozen fires, but I'm looking forward to some time this weekend to play with the bike.  At a minimum I'm going to do the oil change on the bike and the bug, and I'm going to try to sort out the wiring again.  I spent a day getting what I have working going, but the wires have been spliced and changed here and there, and the rats nest up front won't even fit into the headlight bucket right now, I really need to get a multimeter again and test it all out.  I'm also going to bleed the brakes and hope that fixes the "brakes stop working in the rain"  issue.  The front brake is stopping the bike fairly quickly otherwise.  I adjusted the little screw on the back brake once, but it seemed to go soft again in a day or two.  I'm a pretty big moron for riding with less than optimal braking.
I've seen the link for the online parts sources, are there any reliable local sources for parts?  I've heard I can get the oil filter at the local FLAPS, will they have the plugs these bikes need?
Also, I've gotten one of my other firsts out of the way - a speeding ticket, and I managed to get one in my car last october so no traffic school for me.  I think my speedometer might actually be off, I'm hoping to find a shop that can look at that for me, possibly at the same time I am getting the tires changed.
On the 700SC, I've thought about it, but I don't have a key.  To get a key I imagine I need to get a title.  The story from the PO is that his wife was managing an apartment complex and it was left, and it sat there for 6 months while they tried to get the owner to take it and he never did, so it got drug into my PO's garage to get it out of the complex lot.  3 years later I was required to take it with the other two bikes as part of the sale.
Again, sorry for being wordy and lumping 20 issues into one thread, but I'm very excited to find a good forum for these bikes.  My next issue is to find a cheap old bike to mess with that my fiancee can ride.  She's 5'2", and she wants to put feet down so it's a bit of a search.
jdigga
Sounds like you have quite a lot on your plate.
For me, I found it helpful to disconnect everything in the bucket, stretch it all out to see where everything was, and then put it all back together systematically.  Just looking at it all smashed up in there gives me a headache.  Hopefully your wiring harness wasn't modified too much--my 79 had an extra bit of harness spliced in for a fairing, but it was just scotchlocked on so it came off easily and left the original harness intact.  Multimeters can be had for a few bucks at Harbor Freight; having one of those is a must.
Braking in the rain is always going to suck even if you stop well in the dry; it's a function of the rotor and pad being wet and slippery, not the fluid's ability to push the pad against the rotor.  You just have to brake earlier (much, much earlier).  I've also tried with moderate success riding the brake slightly when coming upon an intersection to help the rotor shed water.  I'd rather just not ride in the rain.  ;)  Your rear brake may be ready for new shoes.
As far as online sources go, there's Dennis Kirk, Z1 Enterprises, Parts N More, Cycle-Re-Cycle, and others.  Check the Seller Feedback forum; so far I've only bought from Z1--very highly recommended.  Do you have a local Honda motorcycle dealership?  Sometimes it's easier to get miscellaneous bits there.  Most auto parts store should have your plugs (NGK D8EA I think).
I've found that my speedometer is 3-4mph fast, and I've seen other CBs with even faster speedos.
Key, you don't need no stinkin' key!  ;) Just unplug the connector to the lock and jump the wires in there.  This is, of course, for troubleshooting, diagnostic, and maintenance purposes only.  Not sure if things changed in the 80s, but the number on the lock should be enough to get a key cut.  This guy might be able to help.
Feet down at 5'2"?  I'm thinking only a cruiser-type bike like a Rebel would fit the bill.  Cool that you'll have your better half to ride with.
Offline Gordon
  • 750K1, 550K2
One thing these bikes definitely need to run is a good, charged battery.  The charging system is only adequate to maintain a good charge.  You'd have to ride for several hours at highway speed to even come close to charging the battery all the way up.  Hook it up to a charger on a setting of 2amps or lower, preferrably a self maintaining one, and let it fully charge.  If it won't hold it after that, get a new battery.
Offline Gordon
  • 750K1, 550K2
Oh, and don't go by what the title says for the model year.  Check the VIN on the steering neck and compare it to the model guide on the main sohc4 website to find out the actual model.
Offline turin39789
Thanks, that's on my list of things to do that I haven't gotten around to doing.  And as far as the battery, it does hold a charge okay, it just surprises me that if I leave the key in, either off(pretty sure that happened once) or on it will completely drain the battery.  I'll plug it up to the trickle charger when I get home tonight and hopefully will get my final papers done for this class so I can start ordering stuff for the tune up.  I'd like to get
new shoes/pads
new hoses for carb/petcock(I'm going to get some pictures/video as well to put up so you have a better idea of what I'm fighting)
spark plugs/wires
oil and filter
air filter
From your stated desires, it is unlikely that you will ever like the Cb550 brakes.  Even when you get them to lock the front tire while dry, they will still be different and have less power when wet.  Water acts as a lubricant between disk and pad, reducing friction.   It's both good and bad, really.  I never thought locking the front tire as a good thing, as this tends to get the sides of the bike scraped up from sliding to a stop on it.
The front brake light switch is located in the hydraulic pressure line on the lower triple tree.  See, if it is still connected.
In traffic, I tend to ride the front brake to squeege off the water and keep the disk hot.  This allows you to retain about 1/2 to 3/4 of the brake effectiveness.  Remember, your tires don't have best traction in the rain either.  And, the rear brake still works well enough to lock the rear tire in the rain.  I prefer to keep the tires rolling.  After rebuilding the front brake, replacing the fatigued,expanding rubber front brake lines with braided SS, was the best performance improvement made.  I suspect wet performance would increase if you either drilled rotor and.or cut some channeling grooves in the brake pad.  But, I just allow extra time and space while driving to compensate for wet riding conditions.
Oil change:
Get your self a 6 point, tight fitting socket for that oil filter bolt. And pray that it wasn't overtorqued by the previous filter changer.  Alternatives will leave you proclaiming expletives.
Spark plugs for the CB550 s/b D7EA.  D8EA will make the bike very cold blooded.
Carburetors:
You'll hate removing them from the bike.  Most do, until the technique for extraction/insertion is learned.  It is possible to do much of the cleaning with them in place, though.  You'll have to be limber, clever, devious, and determined to do so, though.  But, check your tank for rust first.  Cleaned carbs only remain so if fed clean fuel.  The 75 petcock has an in tank full screen that can easily be damaged and then let pass debris that can cause the carbs to overflow.
If your tank and in-tank filter check out, then you might consider dropping one of the outer carb bowls, in order to see what kind of glop is inside them.  If foreign ,material will spray off with carb cleaner, you can probably clean them in place.  If you have white corrosion deposits inside or hardened residue that is difficult to dislodge, then you are better off with bench maintenance.  Do get some carb kits from Honda and don't whine about $18 a carb for them.  You're saving over $300 on labor, aren't you?
Split, leaking fuel hoses are best replaced.  Get 5 mm fuel line in bulk from the Honda dealer.
Ticking noise:
Argh.  You could be describing the dreaded cam cover rocker wear.  I've described this and the repair in detail elsewhere in this forum.  Search.  And, have the crying towel handy.  Maybe your parts bike will bail you out.  Maybe you should peruse eBuy for a 77-78 CB550 Cam cover, rocker arms, and cam.  If you can feel the ticking at an inspection cover...weep.
Electrical:
Unless you describe the mods done from the vetter install and removal, it is best to simply point you to the stock wire diagram.  The closer your bike reflect this diagram arrangement the more likely it will work like it did when new.
Work order:
Leaking gas is a fire hazard.  I think I would address that first.  A burned bike and surrounding area can ruin more than just your day.
Electrical would probably be next, for operational reliability.
A full tuneup.
Chain lube/adjust.
Fork oil change
Improve your brakes, or learn to cope, next.
Address the ticking.
I also have one of those 700SCs.    It's a pretty nice bike now that I've taken care of the "little things" that had been allowed to deteriorate.  It's kinda spoiled me.  Shaft drive= no chain lube, adjustment or replacement.  Hydraulic valves= no frequent tune-up.  Electronic ignition= no points or timing adjustments.  I still have to change the oil and put gas in it, though.
Dual disk front brake works pretty well. I haven't encountered rain with it yet,  But, the drilled rotors should help keep it effective.  I'm not at all sorry about the money I've spent on it since it was given to me.  In the picture you posted, yours doesn't seem to be in bad condition.  It's quite a bit faster than the 550 and gets to its 10K redline scary fast.
If you can take the lock off and get to a locksmith, they should be able to make a key for it.  Good ones will anyway.
Offline turin39789
Re: I'm new, I need project and general maintenance advice. Bear with me.
« Reply #9 on: August 01, 2007, 07:26:14 AM »
The rain braking issue isn't just a slower break time.  I grap the front brake and nothing much happens, I have to really squeeze hard(harder than normal) to get any effect out of it.  I feel like I lose 90% of my braking.  It is to drastic to be a normal loss.
Offline turin39789
« Reply #10 on: August 03, 2007, 11:17:25 AM »
I took some pictures of the gas leakage, but havent had time to shrink and post em.  The puddles are coming from the overflow tube, and I think the rest is coming from the gasket, so I think I need to adjust the float level/new needle valves and a new gasket, The rubber going into the carbs looks dry but I know one of the lines going to the petcock leaks a drop now and then.
Any link to instructions for getting in to the carb and  messing with needles/floats?  Where to get replacement parts/what all should I order for the project and from where?
Going to get the oil changed this weekend, I'd like to go back to the stock airboc(came with a pod), where do I get a stock box and filters?  Also I heard this install is a pain, anyone have a writeup?
Offline turin39789
« Reply #11 on: August 04, 2007, 12:41:04 PM »
Did a little photo shoot
« Last Edit: August 04, 2007, 12:44:06 PM by turin39789 »
Offline turin39789
« Reply #12 on: August 06, 2007, 12:27:01 PM »
Nobody's going to make fun of my gas leak or my flashy jacket?  What kind of forum is this?
Managed to get the first oil change done, feeling more confident now that I have actually turned the wrench on the bike some more.  I probably need to make my list of maint to do this weekend soon so I can order parts.  I'll probably try to play with the floats/needles if i can work up the nerve, otherwise I need to oil the chain, and probably lube the front forks,  I have about 13k miles, so I'm going down the 12k tuneup in my clymers.
fuzzybutt
« Reply #13 on: August 06, 2007, 12:38:19 PM »
okay...gay jacket, liberace gay in fact lol. and dude that gas leak is SCARY please fit it now, before you ride again, gas fires are no joke and they will ruin your day in a big way, if youre lucky all you'll lose is your bike. nice looking bike though, you'll enjoy it for many many years as long as you keep up the maintenance.
jdigga
« Reply #14 on: August 06, 2007, 12:45:30 PM »
Damn, you weren't kidding about that gas leak--you're actually riding it like that?!?  Cool bags though.
« Reply #15 on: August 06, 2007, 01:07:15 PM »
I couldn't type before because of the tears in my eyes. :'( :'( :'( :'(    Just thinking what a gas fire would do to my inner thighs and private bits, I wouldn't ride that without a flame suit under that highly stylish jacket.
On the bright side, you may not have to paint flames on the bike for that custom look.
I do hope all your test drives are around the block where the fire station and paramedics reside.
Remembering one of my parental lessons about staying silent if you can't say something nice...
If you park the bike in a pidgin coup for a week or so, those gas stains won't be nearly as noticeable!
(Mom said I never listened to her...)
Offline turin39789
« Reply #16 on: August 06, 2007, 06:50:26 PM »
The gas stains need to be cleaned off, most of that is from a few times that I have left the petcock open and walked away and came back later probably a gallon or a half lighter.   It's not leaking like that when it's running and the past few days I've  been shutting off the gas before I got to my destination and I don't think I've leaked at all. It's been on some 100+mile runs, and gets about 40mpg.
And yea, the jacket took some getting used to, but the hard armor was really nice in a fall.  Once I find a plain looking leather jacket with some hard armor and ventilation I'm going to be ditching this one. I'm thinking about this one - http://cgi.ebay.com/ebaymotors/Stylish-Leather-Armor-Motorcycle-Jacket-Black-44-Armour_W0QQcmdZViewItemQQcategoryZ6750QQihZ014QQitemZ330152285076QQrdZ1QQsspagenameZWDVW, but it's a no name and I can't see it in person/on a person until I buy it.
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #17 on: August 06, 2007, 07:14:10 PM »
If you want, give me a pm on making a key for your  bike and I'll walk you through it.  I lost mine coming from home last week and after hearing the $150 pricetag from the locksmiths, I tore the thing apart and cut my own key.  Wasn't that hard- the actual work took ~30 minutes or so.  Sometime when I get a few hours, I'll work up a how-to for the group.  Seems like it's a common occurance.
dave
Offline mark
« Reply #18 on: August 06, 2007, 09:06:01 PM »
Sorry, I'm not in a position yet to make fun of your drippy carbs.
Didn't I see that jacket(with matching pants) on a guy in Beverly Hills Cop?
If you are still having electrical issues after tidying the rats nest, I would check the fuse box - they are truly evil.
There are numerous threads on the subject - including this one:
http://www.sohc4.us/forums/index.php?topic=20035.0
Happy trails
F you mark...... F you.
jerrit1
« Reply #19 on: August 07, 2007, 10:12:14 AM »
Liberace was gay? he looks completely normal to me...lol
http://www.rbcant.us/th/liberace.jpg
Offline edbikerii
    • Gallery
« Reply #20 on: August 07, 2007, 10:22:29 AM »
Can't you maybe get that jacket dyed at a local dry cleaner's or shoe store or someplace?  Might not be so terrible if all black.  It kind of has that Michael Jackson "Thriller" thing going on.
Brings me back to the '80s...
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline Chris Liston
« Reply #21 on: August 10, 2007, 09:45:21 AM »
Turin,  nice bike, but unless I'm wrong its definitely a K model.  Tank and side covers and frame are all K models.  F's had a cover over the gas cap and smoother side covers without the lip in front over the are box.  Also the passenger pegs mounts on the F's were tubular, not tab like as on your bike.  Since you don't have a title for the 700 should put that front end on your bike to get dual disk and better suspension :)
1976 CB550F Cafe in progress
« Reply #22 on: August 10, 2007, 09:57:51 AM »
The pictures posted are definitely K model.  The F in Four on the side cover does NOT make it an F model.
Offline turin39789
« Reply #23 on: August 10, 2007, 10:13:53 AM »
Thanks, I checked the vins and started to post them, but just checked them with the faq and confirmed in my new thread
http://www.sohc4.us/forums/index.php?topic=25021.0
that it is a 75 k1 and not a 74 f.  I figured I should make a new thread instead of bumping the same old one, just trying to avoid being the pariah of the forums, check the other thread out if you want, looking to feel comfortable on making a purchase of tires and chains/sprockets.  I keep meaning ot write down what kind of 10 year old tires are on there but am constantly forgetting
Offline turin39789
« Reply #24 on: July 05, 2020, 08:52:19 AM »
So, I'm bringing this one back from the 'mostly dead'.  Will get some picture posted soon.
Since buying this as my first bike, I got several years of fun riding out of it.  Did all the work, kept her on the road and commuted for most of the year.
I started to feel like I needed more power so picked up a 78 CB750.  Got a little snowed by the PO but paid to keep it running but never loved it.  Always felt too heavy/just not right.
Then I went and had 5(FIVE!) children, and the bikes have been sitting for a few years.  I got the 550 going again last year, but still plagued by electrical gremlins and the few rides I snuck were cut short because the headlights weren't reliable.  I bought some LED indicator lights and a new main wiring harness, and they have sat in the packaging.
Finally got off my butt.  Sold the 78 without fooling with and I think new owner got a good deal.  Already reports that after oil/gas/battery change she is running(rough but running).  Glad to see it out of my garage where it will actually get used.  My plan was(is?) to use some of that money to pay a good local shop to bring the 550 back for me so I can at least start sneaking in a few rides each month.
Couldn't wait though.  Snuck some time in and pulled the tank and started replacing the wiring harness.  Got to the headlight bucket and had forgotten it was cracked.  New one on the way and hoping to complete that job next weekend.  I'm on an indeterminate wait-list with the local good shop.  There is some oil that has seeped from Cylinder #1, so worried I may be in for some real work and then I start reading through engine upgrades to 650 cams and heads and I think I am getting well ahead of myself.  I expect I can get the electrical sorted myself and possibly save some funds for any engine work needed.  Looking to do a few smart upgrades along the way.  Will depend on how long I can keep getting some garage time without shorting the family.
I want to get her back to roadworthy, but will probably still pony up for the shop to give it a good once over.  I'm still 100% ignorant on all motorcycle suspension issues, maintenance, upgrades or otherwise.  Goal is a mostly stock rider that I can keep maintained for irregular usage so I don't bit the bullet and go with a modern bike.
Current project -
Fix the hideous wiring
New Headlight
Possible soon -
New Exhaust(Delkelvic?  Don't want too loud)
Tank paint is faded, may ride as is or find someone who can handle Sunrise Metal Flake(always loved this color)
Need a right side cover
Tires have plenty of tread, but are aged(where did the years go?)
Regulator/Rectifier?
Hondaman transistor ignition?
ATC fuse block?
New master cylinder(Right mirror mount is fubar'd.  Assume this replaces as one unit)
Brake upgrades?(new lines, stainless, etc?)
« Last Edit: July 05, 2020, 09:06:25 AM by turin39789 »
