Author Topic: cb750 fuel tank on CB500?  (Read 8354 times)
Offline DonParmesano
« on: August 01, 2007, 04:29:47 AM »
Hi!
Has anyone ever put a Cb750 tank on a CB500? Any Ideas about fitment and looks?
best regards
Peter
Offline Caferacernoc
Re: cb750 fuel tank on CB500?
« Reply #1 on: August 02, 2007, 09:03:08 AM »
It's been done. I've done it. You may need to trim the two mounting pegs in the frame to get the tank to slide on but it will work. The other issue is length. The seat needs to be trimmed or moved back slightly for the bigger tank to fit. Looks wise, I like a big tank so I think it's cool. I had a 750k tank on my old '76 550 with a slightly smaller stepped aftermarket seat and it just fit. I recently helped a friend put a 750F seat on his 550 and it was quite a bit too long. We had to change the brackets on his aftermarket cafe solo seat to get it to work. Awesome when done, though.
Offline forwheeldrift
  • 1972 cb 500 Four
    • pics
« Reply #2 on: August 02, 2007, 09:16:20 AM »
There go's that lightbulb again!!
Thanx :-\
« Last Edit: August 02, 2007, 09:18:02 AM by forwheeldrift »
« Reply #3 on: August 02, 2007, 03:05:48 PM »
Thanks for your answer! Could you help me out with a picture of the end result?
best regards
Peter
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #4 on: August 02, 2007, 03:18:39 PM »
Pictures of a really good looker.
http://www.bikepics.com/members/roblloyd/76cb550/
Another post about 750 tanks on 500s
http://www.sohc4.us/forums/index.php?topic=10307.0
1977 CB750
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #5 on: August 02, 2007, 04:11:24 PM »
Here's a pic of a CB750 tank on my CB450 --->
Anything can be made to work, just a matter of if it is worth the time/effort/etc...
Offline hymodyne
« Reply #6 on: August 02, 2007, 07:03:25 PM »
my bike has a 750 f tank on a 500K1 frame (avatar). I had to shorten the seat pan by about 2 inches in the front, and I made a new way for the tank to secure to the frame in the rear. I just ground the horns down for the tank fit up front and shortened the rubbers from the back so they would fit.
I'm running accel coils which are wider than stock but they fit fine.
hym
« Reply #7 on: August 03, 2007, 07:54:29 AM »
Hi!
Thank you all for your answers!
I would LOVE to have this item on my cb 500/4 but it's designed for the cb750 and I don't know if it's possible to make it fit:
  • 1972 cb 500 Four
    • pics
« Reply #8 on: August 03, 2007, 09:29:34 AM »
 :o WoW :o     me to.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: August 03, 2007, 09:52:19 AM »
I second the "wow!" Nice piece of functional art in my book. ;)
Offline ProTeal55
  • Est1968.com
« Reply #10 on: August 03, 2007, 12:03:03 PM »
How much is that #$%* ? ::)
« Reply #11 on: August 03, 2007, 01:09:50 PM »
460 Euros and 90 euros for the "Aero 400 fuel cap"
I am not as cheap as a bastard to not spend that kind of monay! But getting the tank done, paying it, not be able to return it (as it's a one off piece) and realizing it's not possible to fit it to the bike would be to much for me!
Just the tought of this beauty sitting in my shed and not going to be put on the cb500/4 breaks my heart!
best regards
Peter
Offline cafe75-550
« Reply #12 on: August 03, 2007, 11:06:42 PM »
If it will fit a 750, it will fit a 550 if you cut down the front mounting studs on your frame about 1/4". I ran a 750F tank on my 550 with no issues (see avatar and below), you'll just have to come up with a rear mount, since the tank will be too long for the stock one. Will also put you in the market for a new seat, if you're not already running a cafe seat on your ride. There are several other posts on this, do a search, some are more detailed than others, but I know I've posted this info a few times!
« Last Edit: August 03, 2007, 11:10:47 PM by cafe75-550 »
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
gribbs
« Reply #13 on: February 17, 2009, 11:19:43 PM »
What about a 550 tank on a 750???
Offline cafe75-550
« Reply #14 on: February 24, 2009, 05:29:24 PM »
Hard to say, the front mounting cups on the tank will be too wide (the 750 front mount is too narrow for the 550), but the big problem will likely be the 550 tank is shorter. Not sure how much shorter off the top of my head, its at least a few inches, which may cause the rear mount to interfere with the backbone on the frame before the tank sits down all the way...
New bike!
