Author Topic: How to remove burned sticker goo from chrome?  (Read 3572 times)
Offline Chris Liston
« on: July 07, 2005, 10:23:02 AM »
My new MSCS exhausts had these very little Made in Japan stickers on them about the 1/2 dime size.  I pulled them off but in haste to ride didn't wipe off the goo residue they left behind.  Anyway, the pipes got hot and now its on there.  Any idea on how to remove it.  Its only very small spots that cant be seen from over a foot away or unless your down looking for it.
Thanks
1976 CB550F Cafe in progress
Offline Bob Wessner
  • "Carbs Suck!"
Re: How to remove burned sticker goo from chrome?
« Reply #1 on: July 07, 2005, 11:38:53 AM »
Try heating them up again, then wipe with some really fine steel wool before the pipes cool.
Offline MikeDeB
« Reply #2 on: July 07, 2005, 11:40:20 AM »
Give acetone a try.  It's pretty good at removing stuff like that.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline kghost
« Reply #3 on: July 07, 2005, 12:37:42 PM »
I wouldn't use the steel wool on the chrome.
As the previous post suggests try acetone or MEK.
Also Naptha, which is a easy to get solvent. It is the main component in lighter fluid. Try soaking the spot with Ronsen or Zippo lighter fluid, hell barb-e-q fluid will do the trick. Put a piece of paper towl on it an keep it wet for about 5 minutes, Should wipe right off.
Stranger in a strange land
bike54
« Reply #4 on: July 07, 2005, 01:07:45 PM »
try nail varnish remover on a cloth on cold exhausts
bike54
Offline cb650
« Reply #5 on: July 07, 2005, 01:12:55 PM »
Yes acetone or mek do wonders. Please dont use steel wool.  Just aquired another 650 and it looks like someone went over all the chrome with the #$%*.
                          Terry
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: July 07, 2005, 01:41:59 PM »
Gee, I'm sensing my steal wool idea didn't go over too well.  ;) All I can say is '00000' wool and WD-40 worked wonders on my chrome after 22 years. I was only suggesting using it to sort of drag the crap off after it softened again.. assuming it did.
Offline kghost
« Reply #7 on: July 07, 2005, 08:49:37 PM »
The main ingredient - Acetone.
Buffo
« Reply #8 on: July 07, 2005, 09:26:43 PM »
It seems that no one has told you to use the acetone on COLD pipes.
I wouldnt go pouring acetone on pipes that are at CB running temperature. ;D
Don
Offline kghost
« Reply #9 on: July 07, 2005, 09:49:23 PM »
Yeah, Buffo, good point.
Offline mutters
« Reply #10 on: July 08, 2005, 01:01:35 AM »
If the stickers are only glued on I would be looking at eucalyptus oil on cold pipes.
It's pretty user friendly and will clear your airways without causing cancer.
Here in the great downunder we find all sorts of uses for the gear.
Smells good too,avag'day jeff.
I know its only rock and roll,
but I like it...
Offline carl550k
  • 76 550k, 99 honda shadow aero
« Reply #11 on: July 09, 2005, 11:02:21 PM »
there's this stuff at the hardware store called goof-off, its for removing old paint and anything else that leaves goo. works great!
« Reply #12 on: July 10, 2005, 09:13:53 AM »
Yeah, I'm with you Bob.  Even 0000 steel wool polishes up chrome without leaving any scratches.  The coarser stuff will scratch though, as will scotchbrite.
But, it may be too late for the sticker goo.   Even finger oils can permanently discolor the chrome head pipes when they get hot.  It might be worth trying a product called Blue-away.  I don't know how it works.  But, it is a product sold specificaly for the purpose of removing the blue discoloration from chrome head pipes.  It's just a guess that it might work on glue contamination, too. Look here:
http://www.leaderboardgolf.com/shopblueaway.htm
or just google  "blue away chrome"
Offline Trevor from Warragul
« Reply #13 on: July 11, 2005, 12:08:27 AM »
WD40 works.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #14 on: July 11, 2005, 07:57:02 PM »
Chris, You may find the goo will burn off to a powder. I would use plain denatured alcohol which will dissolve most anything but chrome.  One of those plastic scub pads would help a bit.
Offline SCJIM
« Reply #15 on: July 18, 2005, 09:22:50 AM »
i dunno if its too late to offer my 2 cents worth but here goes...
try "zippo lighter fluid"
just a little on a cotton ball or Q-tip and that old stickey crap should come right off.
plus you can find the stuff just about anywhere.
ps: verry improtant,  do not do this near open flame!  and wash off area with soapy cloth after.
Jim in SC
1981 CB 650 Custom
Offline kghost
« Reply #16 on: July 18, 2005, 11:13:58 AM »
Yup, Main ingredient - Naptha
Offline Egil
SV: How to remove burned sticker goo from chrome?
« Reply #17 on: July 21, 2005, 01:14:09 PM »
IF we have problems  like scraths on Windshilds/Dirty no shine, we shine up Honda engienes /Dirty/rusty we shine up Exhoust pips
WE by somtig  name  AUTOSOL  it coms in 100 grams tub AND 1000grams bags
It`s a Unirversal polish we her in scandinavia  us to this problem
I hope this can help you on the way!
Egil
Norway
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
