Author Topic: Swingarm Stand Complete  (Read 4469 times)
Offline jdawg
« on: August 02, 2007, 08:19:06 PM »
I removed the center stand, but still wanted a way to pick up the rear end (change tire, chain - whatever). So I built my own swingarm stand. I copied a forward handle model made by Pitbull. It gave me a chance to practice with the new welder and horizontal band saw. Came out pretty good. I wanted the forward handle so I could hang on to the bike as I step on the handle. On my brother-in-laws race bikes we used rear handles, but the bikes were a couple of hundred pounds lighter (Yamaha TZ250's) and there was alway someone around to steady the bike as you positioned the stand and lifted it. Anyway, it was a fun little project. Enjoy.
PS - It's hard to see...  but that's a 550 swingarm on a 750
« Last Edit: August 02, 2007, 08:20:49 PM by jdawg »
1974 CB750 K4 - old junk to fiddle with
Offline dusterdude
Re: Swingarm Stand Complete
« Reply #1 on: August 03, 2007, 01:12:50 PM »
i like that.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline ekim98
« Reply #2 on: August 12, 2007, 07:00:13 AM »
 Can you give us any dimensions. What size wheels did you use.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline jdawg
« Reply #3 on: August 13, 2007, 03:44:55 PM »
The wheels are 2.5" dia. The vertical legs are 14.5" and it's 9.5" between the legs (inside). The verticals are 1.25" and the L's are 3/16. All the hardware is grade 8 (overkill) 3/8" bolts.
Anything else let me know.
Offline edbikerii
    • Gallery
« Reply #4 on: August 13, 2007, 03:51:28 PM »
That's purdy.  I might give that a try myself.  I'm starting get rusty with the welder, and need a refresher project.  Nice job!
What's at the top there?  Are those pieces of hose wrapped around bolts and zip-tied in place?  How's that work for you?  Does it slide around on the swing arm while lifting or anything?
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline jdawg
« Reply #5 on: August 15, 2007, 09:08:32 AM »
edbikerii - Thanks for the comments and support.
The top pieces are 3/16 angle iron with 3/8 bolts thru into the 'L' area. The bolts are grade, cuz I'm an 'over'engineer (at least that's what the wife says). I put rubber hose over the boilts so they don't scratch the swing arm. Once the bike is up and on the stand, it does not slide. While you are cantilevering it up the hose allows for some rotation onto the bolts. The thing is pretty sturdy. Only thing I would change is make the handle longer, more better leverage.
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #6 on: August 22, 2007, 07:42:52 AM »
Me Likey 8)
A lot ;D
1978 CB550 K3
1985 H100S
Offline Johnie
« Reply #7 on: August 23, 2007, 05:12:24 AM »
If you are not putting that center stand back on that 74 CB750 let me know.  According to the parts fishe it is the same as my 1970 CB750.  The guy I bought the bike from put on after-market exhaust and had to bend one of the stand legs to make it fit.  So now the bike leans to one side.  If you think it is worthy of me sanding and painting let me know if you want to sell it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
