Author Topic: Float bowl gaskets  (Read 4491 times)
Priscbs
Float bowl gaskets
« on: August 03, 2007, 09:22:24 AM »
Is there any good source to get JUST the float bowl gaskets without buying the hole darn kit?  Has anyone tried using a large rubber o-ring?
Offline HITMAN
Re: Float bowl gaskets
« Reply #1 on: August 03, 2007, 12:28:22 PM »
There is one auto parts here that sells rolls or measured lengths of o-ring stock, find one in your area tell them the diamater and application to determine the composition you need, cut it to length with a sharp razor and super-glue the ends together.  If your unsure about the DIA of the squished one you have, measure the hight and width with a caliper and add the two together and divide by two.
If you cannot find someone that has the o-ring stock, find a local machine shop in your area and ask them if they have it or know someone that does.
1974 Honda CB550F
1984 Honda GL1200A
2003 Honda CBR1100XX
Offline dusterdude
« Reply #2 on: August 03, 2007, 01:02:34 PM »
or take a bowl with you,or smoke a bowl whatever turns you on. ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #3 on: August 06, 2007, 02:12:42 PM »
CRC sells them also
1977 CB750
« Reply #4 on: August 06, 2007, 04:43:42 PM »
So does Honda
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #5 on: December 18, 2007, 12:09:15 PM »
you might try oldbikebarn.com.  they run about 13 bucks apiece i think.
MATT
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #6 on: December 18, 2007, 01:28:05 PM »
For 12 bucks you can get the whole kit....
Try
http://www.olypen.com/retro
Found real friends here !!!
Offline tortelvis
« Reply #7 on: January 24, 2008, 01:11:27 PM »
So does Honda
Well that's news to me! I work at a Honda dealer and have never seen Honda carb gaskets sold except as a kit.
Offline mrblasty
  • Expertly
« Reply #8 on: January 25, 2008, 07:43:22 PM »
So does Honda
I was able to buy just the bowl gasket from a honda dealer about two years ago
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline azuredesign
  • Knupping pin
« Reply #9 on: January 26, 2008, 04:55:02 AM »
I'm also pretty sure I got a set of 4 from our local Honda dealer this past summer. '73 750k
The only other place I might have ordered them from was Z1.
