Author Topic: Sailboat ID  (Read 585 times)
upperlake04
Sailboat ID
« on: August 03, 2007, 10:40:56 AM »
  Picked up this 13'3" x 5'3" beam (mostly) cosmetic project on trailer with 4 sails for $200. Appears to be owner built to a racing Class spec. - many parts and the sails are marked with the same 5 digit number.       Does anyone recognize what that class might be? An internet search wasn't fruitful.    Thanks,  Dave.
Offline Rushoid
  • Shameless
Re: Sailboat ID
« Reply #1 on: August 03, 2007, 11:49:29 AM »
Can't help you, Dave, but that looks cool. $200 seems like a steal! Might wanna fix that hole before you put her in the water though ;) I might be getting one similar to this http://www.sailingtexas.com/smacgregor22j.html soon from my father-in-law. It's been sitting for about 15 years or so, outside, so it needs a lot of work. I don't know much about sailboats, but I guess I'm gonna have to start learning.  :o :o ;D Good luck with it!
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
Offline greenjeans
  • 1972 CB750K2
Re: Sailboat ID
« Reply #2 on: August 03, 2007, 02:23:05 PM »
It might be a home-made boat....from a kit or purchased design.
Doesn't really look like a mass produced racer...
I'll see if my pops recognizes it - looks fun
Offline Carbine
Re: Sailboat ID
« Reply #3 on: August 03, 2007, 02:53:40 PM »
That, my good man, is called an Enterprise. It's a One Design class, it's origin is in the U.K. There was a class certified builder in Saskatoon who built woodies there in the late 1950's, and they later did some hulls as well in FRP.
.....it was designed by a guy by the name of Jack Holt, a well known yacht designer from England, in the mid 50's.
...watch out, they are fast boats! If you have never sailed before, try sailing her under the mainsail alone. Put the jib up when your ready. If the wind comes up, get ready to hike your ass out. Get the jib down if things get too wild. This boat is designed for a crew minimum of 2, so don't try singlehanding, except in very light air. If you capsize, you won't be able to right the boat by yourself.
...some of the Saskatchewan built FRP boats have flotation problems, i.e. they can sink. As I remember, the woodies were ok, but as a precaution, I would take the boat into shallow water just off shore and capsize it. See how it floats and what it takes to right it. That way will you know what your up against......for when it happens for real....and it will. And when it happens for real, the wind will be up, you will have waves to contend with, and will be tired after a few minutes in the water...so be ready. All part of the fun when your a dinghy sailor....... ;D.......Cheers
« Last Edit: August 03, 2007, 05:25:52 PM by Carbine »
'76 750 K6 Candy Antares Red
'75 750 F0 Candy Sapphire Blue
'74 750 K4 Boss Maroon Metallic
'73 750 K3 Maxim Brown Metallic
'72 750 K2 Flake Sunrise Orange
upperlake04
Re: Sailboat ID
« Reply #4 on: August 03, 2007, 03:55:14 PM »
 ;D ;D ;D ;D    Thankyou Carbine!   Great info - possibly 50 years old :o     All mahogany solid and ply and definitely built by a craftsman. There are several pieces of Jack Holt stamped hardware on it and one set of sails was made in England.  Geez this is a great site ;D
    Your capsizing test is an excellent idea - this boat will be taken to our (cold water)  wilderness cabin in northern Sask. where there will likely only be self rescue.  This afternoon I set up a 15' x 20' tarp to work under -I have two weeks to get it into shape. :D :D
     Thanks for the replies Rush and Greenjeans :)
