Author Topic: turn signals wont blink  (Read 4436 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: August 03, 2007, 08:08:45 PM »
just hooked up my turn signals and they wont blink they light with headlight. They actually turn off when i switch to either signal side and light when i turn them off. i changed the wires both ways and they do the same thing either way...let me know if anyone can help me.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline 333
  • Time for change
Re: turn signals wont blink
« Reply #1 on: August 03, 2007, 08:30:56 PM »
Front only?  Or both front and rear?  The stock T/Ss won't flash if both are hooked up.  And if the front ones have running lights, they go out when the T/S is on.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
  • stupid gloripope
« Reply #2 on: August 03, 2007, 08:34:24 PM »
the back ones are off untill i turn the signal on then they stay on and dont blink....does anyone know what i might be doing wrong.
Offline 333
  • Time for change
« Reply #3 on: August 03, 2007, 08:36:37 PM »
How many wires are on the front ones?  What color are the wires?
  • stupid gloripope
« Reply #4 on: August 03, 2007, 08:42:01 PM »
red and black
Offline 333
  • Time for change
« Reply #5 on: August 03, 2007, 08:43:45 PM »
Must not be stock.  What color wire are they hooked to on the harness?
Offline mark
« Reply #6 on: August 03, 2007, 08:51:25 PM »
Mine wouldn't blink worth a darn unless the engine was running and the alternator charging - kind of iffy then.
Replaced the ancient blinker with one of those electronic relay types - nice and steady all the time.
Just one catch - it will still flash if a bulb goes bad.
Happy trails.
F you mark...... F you.
cdaviscomps
« Reply #7 on: August 03, 2007, 09:16:40 PM »
I just replaced the turn signals on my CB650 and when I hooked the wires up wrong they wouldn't blink either. The front turn signals should have three wires, and the rear two wires. The rear are easy to hook up the front are tough taking the factory turn signals off and putting after market ones on.
I would say read the post with the turn signal wiring diagram under the tech section and swap wires.  I tried to find the post but it has been a long day and could not find it but it helped me tons.
  • stupid gloripope
« Reply #8 on: August 03, 2007, 09:18:36 PM »
my factory signals only had two wires.
cdaviscomps
« Reply #9 on: August 03, 2007, 09:50:24 PM »
My rear signals only had two wires, but the front ones had three for the running lights. I tried to put some small after market sport bike signals on it while waiting for my replacements to get here. They were giving me the same issue you are having except it was only the left one that wouldn't blink the right was fine.  Just waited for the replacements and they worked great with a little trimming to get them on the bike.
jdigga
« Reply #10 on: August 04, 2007, 05:43:29 AM »
In your headlight bucket, the stock reflectors (which is where I assume you have now mounted your turn signals) were each held in place by a bolt with a green wire attached to it.  If you still have those in place, find where the green wire plugs into, unplug it (if you haven't already) and try plugging either the red or black in there (I can't remember which at the moment).  You won't have running lights but they'll blink.
  • stupid gloripope
« Reply #11 on: August 04, 2007, 06:07:47 AM »
no reflectors on my bike it is a 1980 cb650
Offline mick750F
« Reply #12 on: August 04, 2007, 07:00:03 AM »
   Sounds like a grounding problem. If you have 2 wires going to your front running light/directionals then they are grounded through their mounting. Check to see that you have good metal to metal contact all the way to the frame.
Mike
Glosta, MA
Offline edbikerii
    • Gallery
« Reply #13 on: August 04, 2007, 07:06:13 AM »
Are you sure that they are dual filament turn signals?  LP Aftermarket dual filament turn signals on my bike came with three wires.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
  • stupid gloripope
« Reply #14 on: August 04, 2007, 07:13:37 AM »
yes they are turn signals here is a pic
  • stupid gloripope
« Reply #15 on: August 04, 2007, 07:15:28 AM »
there was only two wires hooked up orignally on my cb650
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #16 on: August 04, 2007, 09:46:33 AM »
This maybe or may not be of help, but I had the same problem on my RG500.  Indicators wouldn't flash, so after replacing the flasher relay, I still had the same problem.
It turned out to be the wrong wattage bulbs fitted by the previous owner.
jdigga
« Reply #17 on: August 04, 2007, 10:57:30 AM »
So what are the things on the side of the headlight in this picture of your bike that you posted in your thread about dropping the front fork?
And when edbikerii asked you if you had dual filament signals with three wires, you said yes and reposted the picture of them, in which they clearly have 2 wires.
We can't help you fix your problem if you don't help us first by thoroughly explaining the problem and what steps you have taken to try to correct it.
Find the wiring diagram for your bike here: http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php#class and see if it matches up with what you have.
Offline edbikerii
    • Gallery
« Reply #18 on: August 04, 2007, 11:11:59 AM »
I think I'm not being clear on the differences between single and dual filament bulbs.  Also, the stock wiring differs from the aftermarket wiring slightly.
I stumbled upon my old stock front turn signals, and sure enough there are only two wires, even though the bulb has two filaments.  The ground was accomplished through the metal housing of the turn signal onto the fork ears.
My aftermarket FRONT turn signals, which have dual filaments inside the bulb (one for running light, one for turn signal), have a distinct third wire for the ground, however.
My aftermarket REAR turn signals, which have only one filament inside the bulb (one for turn signal only), have only two wires.
I hope this helps.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
  • stupid gloripope
« Reply #19 on: August 04, 2007, 04:00:41 PM »
that isnt a picture of my bike..it is a similar one with the same turn signals....they are both two wire turn signals. the oem ones i took off and the aftermarket ones I am trying to put on...tried hooking both wires up different ways the wires i am hooking to are light blue and orange,,,,,one of each solid orange and one is white and orange....the other is blue and striped blue and white.....both aftermarket signals have a red and black wire. like I said they both light up and when i hit the switch no matter how i hook it up one goes out and the other one stays on but no  blinking either way....I tried to different bulbs already to.
Offline edbikerii
    • Gallery
« Reply #20 on: August 04, 2007, 04:27:29 PM »
Reggie, are you sure the ones you'd like to use on the front are "dual filament"?  Do you clearly understand what I'm trying to ask?  If not, I'll gladly try to explain better.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
  • stupid gloripope
« Reply #21 on: August 04, 2007, 05:50:56 PM »
what do you have to look for to see if there dual fillament
Offline mick750F
« Reply #22 on: August 04, 2007, 06:00:25 PM »
   Look into the socket where the bulb goes. If there are two contact points then it's for a dual filament bulb. If there's one contact point then it's for a single filament bulb. Do your new signals have metal to metal contact when they are mounted on the bike? You need metal to metal contact for them to be grounded. If they aren't grounded then they won't work properly.
Mike
Glosta, MA
jdigga
« Reply #23 on: August 04, 2007, 06:13:14 PM »
Did you try what I suggested earlier?  In the headlight bucket look for a green wire with a double end.  Since you said you don't have reflectors, there should be one free.  Plug one wire from your turn signal into the solid light blue & orange leads and the other wire of each into that double green lead.  This way you are ensured to be plugged into a ground.  Leave the blue/white stripe and orange/white stripe ones empty.
I ran into the same issue you are having when I installed my aftermarket signals except my y signals have a black wire and a black/white stripe wire.  I'd say try the red wire to the blue and orange leads first, but it might be the opposite.
  • stupid gloripope
« Reply #24 on: August 04, 2007, 06:35:05 PM »
Yeah i tried the green wire thing once and it didnt work I will have to check in the morning if they are dual filament and maybe try the green wire suggestion agian.....my back signals arent working right either might that mean something or is that just because the front and back work together.
