Author Topic: turn signals wont blink  (Read 4434 times)
Offline mick750F
Re: turn signals wont blink
« Reply #25 on: August 04, 2007, 07:31:05 PM »
  How and where are the new lights mounted on the bike? On your new lights is that some sort of rubber grommet that might be preventing them from being grounded? Did you have stock lights on the bike and did   they work? If so then the new lights most likely are not grounded. Man, I feel like I'm smacking my head against a wall...sorry, I'm a bit cranky right now. Do you understand that anything electrical has to be grounded in order for the circuit to be complete?
Mike
Glosta, MA
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« Reply #26 on: August 04, 2007, 07:44:22 PM »
yeah I understand it has to be grounded. There is a a rubber grommet but there is a washer behind it....I am mounting it in the head light bucket so it is boltand a washer agianst the headlight housing then there is a rubber grommet and then the light.....the rubber is the black in the picture.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline 333
  • Time for change
« Reply #27 on: August 04, 2007, 07:44:56 PM »
Let me guess.  The rear lights are hooked up to green(ground) and orange or blue(left or right respectivly).  You need to wire the front as follows:  Black wire from T/S to green wire on the harness.  Red wire from T/S to orange or blue(left or right respectivly).
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
  • stupid gloripope
« Reply #28 on: August 05, 2007, 07:08:52 PM »
i took one of the bulbs out and it was a single filament guess i will have to go to the auto parts store tomorrow and try and get a dual filament....
Offline sandcastcb750
« Reply #29 on: August 05, 2007, 07:18:59 PM »
You've got some wires mis-matched. Look on the internet and find a color diagram. The good news is that just about all the 1968-1978 Hondas use the same colors (I believe) and once you memorize them, the next job is easy.
Offline 333
  • Time for change
« Reply #30 on: August 05, 2007, 07:55:32 PM »
Changing the bulbs won't work without changing the sockets.  Try wiring them as I posted in my last post.  This should make them blink.  They won't be running lights, but they will blink.
Offline edbikerii
    • Gallery
« Reply #31 on: August 05, 2007, 08:21:06 PM »
Reggie,
It is not just the bulb you've got to worry about.  The socket has to have the right contacts, and you've got to have three wires, too.  Check with your supplier whether they have the same turn signals in "dual filament" or with "running and turn signal" configuration, then exchange one pair of single filaments for the duals.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
  • stupid gloripope
« Reply #32 on: August 06, 2007, 05:55:27 AM »
the bulb and socket are together it is all one....I didnt check the other set yet.
  • stupid gloripope
« Reply #33 on: August 06, 2007, 06:04:00 AM »
333 i tried the hookup to the green wire and it still didnt blink.
  • stupid gloripope
« Reply #34 on: August 06, 2007, 11:09:03 AM »
I would like to thank 333 edbikerii jdigga mike750f and sandcast for all there help here. I was never a fan of wiring in cars and this is my first cycle....I am at work now but when I get home I am going to take another shot at it....I am taking it that on the single contact bulb if i hook the black wire to the green and the red to the solid color it might work and I am going to try everything else to.....I am keeping my fingers crossed.
Partsbiker
« Reply #35 on: August 06, 2007, 05:37:08 PM »
I had this problem...so i just removed my blinkers
  • stupid gloripope
« Reply #36 on: August 06, 2007, 06:48:37 PM »
got it to work you guys are awesome black to green I actually have about three sets of extra green wires..ground...and red to the color depending on direction and wammo thanks guys.
