Author Topic: CM400T Timing  (Read 1166 times)
Offline Red750K1
CM400T Timing
« on: August 08, 2007, 10:33:00 AM »
How do you check the timing on a 1979 CM400T?  I saw a little pointer on the stator side of the engine case and the rotor has T and F marks. Do you take the whole stator engine cover off to check it or am I missing something?
Offline KB02
Re: CM400T Timing
« Reply #1 on: August 09, 2007, 04:57:11 AM »
since the bike has a CDI ignition, timing is set at the factory and cannot be adjusted.
BUT, to answer your question, yes, the cover must be removed to check.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline crazypj
  • I'm brill, me
Re: CM400T Timing
« Reply #2 on: August 09, 2007, 10:14:38 AM »
and timing is adjustable if you know how. Its worth checking as some were several degrees off ( not that it really caused any problems but they can be lower power as a result)
PJ
