Author Topic: Vacuum level for synching carbs?  (Read 1179 times)
Offline azuredesign
  • Knupping pin
« on: August 09, 2007, 09:27:40 AM »
The Clymer says synch carbs to lowest level or 8". I think Mike Rieck suggested I synch to the highest carb reading. Can anybody clarify this for my quickly as I'm awantin to get this done?
Thanks for your help,
Ben
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Vacuum level for synching carbs?
« Reply #1 on: August 09, 2007, 09:35:39 AM »
I use a Morgan Carbtune 2 to do my 400, set idle to about 2,000 then adjust up or down whichever is easiest, always seems fine after, just use the numbers as a reference.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline azuredesign
  • Knupping pin
« Reply #2 on: August 09, 2007, 09:41:34 AM »
Thanks, I'll bring the idle up some before synching. It raises a question for me, as I wonder at what engine speed the slides and needles start to open at. They should already have started to open at 2k RPM, shouldn't they?
Thanks again,
Ben
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #3 on: August 09, 2007, 10:31:20 AM »
I synched my CB750F1 to the highest one which I seem to recall being 15ish.  I set my idle at 1500.
The Morgan carbtune instructions emphasized  that the number on the gauge was minimally important, it is the relationship of the cylinders to each other that matters.  Can't say that I understand the science of it very well, but it clearly worked.
A hint I would give:  make small changes (1/8 turn or so) and bump your throttle after every change, then give it several seconds to settle down before changing things again.
Use a fan or something to blow air over the fins and (obviously) work in a ventilated space.
« Last Edit: August 09, 2007, 11:29:05 AM by gregimotis »
Offline azuredesign
  • Knupping pin
« Reply #4 on: August 09, 2007, 10:56:43 AM »
Thanks Greg,
I think that what is happening is that maximum vacuum is attained when the slide( and needle) are seated, just the idle circuit is functioning. synching here should balance the idle circuit of all carbs. Bringing the rpm up should cause a bit of a drop in vacuum, showing where more gas and air are introdced as the slide starts to open. Balancing here should help to make sure the carbs are balanced at midrange. I think that checking spark plugs after running at revs consistent with the thee circuits is probably a good idea as well. I wonder what affordable instrument can be used to accurately check mixture while running the bike.
Best,
Ben
Offline edbikerii
    • Gallery
« Reply #5 on: August 09, 2007, 04:27:23 PM »
I don't know what bike you're tuning, but on the 77 550 K carb #2 is fixed and cannot be adjusted.  The other three are tuned to match it.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
