Author Topic: Results of Sparty's New Wiring Harness Install.  (Read 1247 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: August 10, 2007, 07:38:08 PM »
Well guys, it wasn't as difficult as I thought it would be.  But it was still a PITA.
My bike is a 1972 CB750, tha harness is for a 1973.  There is a difference between the two harnesses, but it does work.  In the headlight bucket I tried to make every thing as neat and clean as possible... no small feat.  I do have extra connections however that are not used.
I also connected a 1973 key switch, with square end, to my bike.  The 1972 used a round connector to the harness.
I intalled a new starter selonoid also.
I have not put any power to the harness yet, I am waiting for the 1973 fuse box to arrive.
God, I hope it works.
One question, where on the frame did the original harness attach?  My old harness was modified and it ran along the center frame tube.
Sparty
1972 CB750 K2 Cafe' Style
Offline Jonesy
  • Shop Rat
Re: Results of Sparty's New Wiring Harness Install.
« Reply #1 on: August 10, 2007, 07:43:55 PM »
Art- That manual I sent you has a page with a diagram that shows the stock wire harness routing. The stock harness runs along the central tube above the engine.
Offline sparty
    • Gallery
« Reply #2 on: August 10, 2007, 07:45:09 PM »
Thanks.
I thought that it should be run that way.
Offline Jonesy
  • Shop Rat
« Reply #3 on: August 10, 2007, 07:48:12 PM »
Here's the diagram:
Offline CBNJ74
  • Sweep the leg!
« Reply #4 on: February 26, 2012, 06:04:52 AM »
Could this be done without major disassembly or engine removal?
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
bollingball
« Reply #5 on: February 26, 2012, 09:00:08 AM »
@ CBN   about the only thing you have to remove would be.
1) Gas tank
2) Head light bulb
3) side covers
No engine removal
                                      Ken
