Author Topic: Gauge face scans...  (Read 17865 times)
Offline kghost
Re: Gauge face scans...
« Reply #25 on: August 15, 2007, 08:24:39 PM »
I highly recommend as I have said to several in an E-mail....
That you leave the odometer/tripometer windows OFF the final version.
This allows you to cut with a razor blade where the window is and not have any residual black.
Use the two screws and the center needle spots for line up.
In fact when I do mine I put the two screw holes on the end of two picks..peel the adhesive back and line up the two screw holes on the gauge.
Otherwise alignment gets iffy and you can slide them all over the face.
When you are done the screws themselves cover the black dots.
Also recommend you delete the black line around the gauges most outboard edge....
then you can stick them on and trim around with a razor blade as well.
Stranger in a strange land
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #26 on: August 15, 2007, 08:42:52 PM »
Absolutely.  I'm just leaving the boxes so nothing ends up there(or something does like Betty Gauge) and I can balance the layout around them.  I wouldn't want "rpm" to end up too close or in the cutout.
Likewise with the outer edge on the white faces.  But if it's a black or colored face, I'd enlarge the outer black/colored area so there is a bleed so there isn't a thin white line left if alignment is off by a hair.
1977 CB750
Offline jonbuoy
    • My rebuild:
« Reply #27 on: August 15, 2007, 09:07:33 PM »
They all look pretty trick - what are you guys using to edit them?  What paper are you using to print onto?
Offline dustyc
  • 1977 CB750K
« Reply #28 on: August 15, 2007, 09:31:19 PM »
Adobe Photoshop and Illustrator.  Illustrator is vector art which is scalable up and down with no loss in quality -perfect for solid color objects like the scales, checkerboard, numbers and representations of the holes, cutouts and overall outline.  Photoshop is raster art (photographic images) which is where you would put in Betty Page or other non-line art image.  I'll end up printing them on an adhesive vinyl.  The printer is 5' wide, so I'll end up making a bunch of styles before I print any.
I'm thinking of making backing plates as well and selling an easier way of changing faces.  That way people could keep their old faces and wouldn't have to hassle with getting the decal straight.  I'm still thinking about what material I'd use for the backing plates.  Considering the way one set I have here have warped and shrunk, I think a thin gauge steel would be the way I'd go rather than plastic.
1977 CB750
Offline Joel
« Reply #29 on: August 15, 2007, 09:41:24 PM »
Are the SOHC gauges not lit at night?
Offline Jugghead
  • I just THINK I'm a
  • 350cc of pure FUN
« Reply #30 on: August 15, 2007, 09:43:57 PM »
Yes, they are, by two tiny bulbs, type 56? i think?
9/72 CB350F...15k miles and rising
Offline dustyc
  • 1977 CB750K
« Reply #31 on: August 15, 2007, 09:45:18 PM »
Yes, but from what I see, the light doesn't pass through the face, but comes in around the edge.
One set I have ('72 500) is actually a metal face.  The green one (550) has green paint on the back.  I'll have to check the shrunken blue (750?) gauge.  I think it was plain white on the back.
« Last Edit: August 16, 2007, 12:06:26 PM by dustyc »
1977 CB750
Offline dustyc
  • 1977 CB750K
« Reply #32 on: August 15, 2007, 09:52:05 PM »
The blue gauges are actually on blue plastic.  And I double checked that the light does come in from around the face.
« Last Edit: August 16, 2007, 12:10:39 PM by dustyc »
1977 CB750
Offline kghost
« Reply #33 on: August 16, 2007, 08:36:19 AM »
Theres actually a couple colors of plastic used...on the 750 anyways.
I've found that a little mek or acetone removes the honda original markings rather well.
Mine are on a green plastic and with white gauge faces glow a lovely neon green at night.
Additionally the inside of the gauge is painted green as well...helping to impart the color from the white bulb.
Buddy of mine has his internals painted a great orange...makes a nice visual at night.
Ya could conceivably paint the internal parts any color you wanted to get the color your shooting for.
Offline ElCheapo
    • Anubis Cycle
« Reply #34 on: August 16, 2007, 09:37:31 AM »
FWIW, I ordered a pair of gauge faces (and paid) from Anubiscycle three weeks ago. Called last week and was told they'd be shipped. Today still nothing and they don't answer the phone.
Please send me another email straight so that we can make sure this is happening the way it is supposed to. I never try to rip anyone off. Things have really hit the fan here with the divorce, so I would like the chance to fix this whole mess. There is a reason why some people here think I am a stand up guy and I want to show proof.
Anyone who has order and did not get thier faces yet (I think there is like 3 customers) please send me another email so that we can make things right. Make sure you have all the goods as far as transaction goes in the email. I WILL MAKE THIS RIGHT.
Cheers
Thomas Neubauer
« Last Edit: August 16, 2007, 09:39:47 AM by ElCheapo »
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
Offline zanzara
    • the hall of photos
« Reply #35 on: August 16, 2007, 09:58:53 AM »
I had made new complete faces from 1/8" clear acrylic. The face was on a translucent to combat that. They light up nice now, however I am in the mood for change so... You can semi see them here
http://www.sohc4.us/gallery/v/members/personal/zanzara/DSCF2428.JPG
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« Reply #36 on: August 16, 2007, 11:31:51 AM »
what kind and brand of paper and where can you get it.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Joel
« Reply #37 on: August 16, 2007, 07:54:51 PM »
I'm curious as to why the redline on the tachometer isn't simply filled to the end of the scale or the scale isn't simply ended earlier.  Any specific reason for this?
Offline dustyc
  • 1977 CB750K
« Reply #38 on: August 16, 2007, 08:11:06 PM »
I wondered that myself Joel.  I guess if you get beyond the red you're ok.
Anyone?
1977 CB750
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #39 on: August 16, 2007, 08:14:32 PM »
At the end of the red line color is where your engine will blow up! ;D  They made it that way so that you knew it was quiting time.
Sparty
1972 CB750 K2 Cafe' Style
Offline russouno
« Reply #40 on: August 22, 2007, 11:30:08 PM »
So did the guy that ordered a set of gauge faces from ANUBIS CYCLE recieve them yet??
I ordered a set almost 3 weeks ago and still don't have them... I also called AND left a detailed message along with an email... nothing!  WTF
This is just not cool at all. ??? :-\
I just read his prior post.  I've now sent another follow up email. :|
« Last Edit: August 22, 2007, 11:49:59 PM by russouno »
knack
« Reply #41 on: August 23, 2007, 05:33:21 AM »
Nope. Got an email from him saying they'd been shipped, then another one saying the ones I had ordered (no redline) weren't in stock. ??? Asked if I'd take 'em with a redline. Haven't seen or heard anything since. Oh well, I don't really want 'em anymore. :-\
Offline c91x
« Reply #42 on: August 23, 2007, 07:01:51 AM »
yeah i'm in the same boat got the email saying they were shipped and now i've done my own and had my print shop print them up.... if he'll just give me a refund i'd be happy
Offline russouno
« Reply #43 on: August 23, 2007, 02:46:09 PM »
Hmmmmmmmmmmmm....  :-[ :-\
Zane
« Reply #44 on: August 23, 2007, 05:02:31 PM »
You might have seen these - they're pretty boring, but they work for me.  I made scans of the originals (for size mainly) and then printed on Epson Enhanced Matte Paper.  (I really like a super flat meter face finish.  The definition is not as crisp as other papers, but I'm happy to trade a bit of resolution for an almost totally non-reflective finish on the face.)
After cutting everything out (Olfa compass knife and conventional hobby knives) I coated the prints with Krylon Archival Preservative (rattle can).  After two years and a bit the tach red is slightly faded.  When I slap in my latest tach face, I think I'll try actually painting in the red with the same hobby paint I used to do the needle tips. (And after having been to the States a few times since making these - I will for sure make the mph inset numbers a little easier to read.....)
I had a lot of fun doing mine too.  I made a bunch of different faces, but I ended up settling for the more conventional look of these (except for the little cop car at 160 and the name of an old friend on the bottom of the speedo who was foolish enough to kill himself driving like a knob.)  I couldn't resist putting my own name on either.  (Hey, at least it's more or less discreet.....)
I use stainless aircraft safety wire to "sew" my rings on.  I also add just the tiniest dab of JB weld to hide the wire.  If you place the cut in the right spot when reassembling the 400/4 gauges, you pretty much can't see it anyways.  My biggest problem was actually with the voltmeter ring - the housing is much smaller than the (already small) tach and speedo - so any joining work is proportionally larger.
I like this system of ring reassembly because it's really easy to get back inside the meters (for lubing and to swap out the faces).  It might not work as well for those bikes where the meter placement isn't so advantageous to hiding the join as is the 400F.
« Last Edit: August 23, 2007, 05:05:49 PM by Zane »
Offline kghost
« Reply #45 on: August 24, 2007, 06:01:09 PM »
I'm still at a loss as to why guys are cutting thier gauges open....
I pry them open carefully and reuse the ring......
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #46 on: August 25, 2007, 06:24:21 AM »
                Been kinda distracted lately but finally saw and checked out this entire thread. You all have some GREAT stuff here! 8)  This should be in the FAQs or somewhere, so that it doesn't get away, don't ya think? ??? ;) My self, I'm liking the classic look of the Vintage style, for the most part. 8) Maybe that's because I'm starting to FEEL vintage! ::) ;D Keep up the good work! ;)
                                   Later on, Bill :) ;)
Member # 1969
chrismo
« Reply #47 on: August 25, 2007, 03:01:14 PM »
Great idea!
Could someone post a link with an .eps file?  I think the 750 and 550's have the same guage size dont they?
Thanks,
Chris
Offline dustyc
  • 1977 CB750K
« Reply #48 on: August 25, 2007, 03:40:40 PM »
I won't mind once I have them done and cataloged.  I'd be happy to give something back to this community.
If we can work it out, I'll upload the stock ones, then what anyone wants to do with them from there is up to them.  That way anyone that wants to just  replace them will be able to take them to a printer, or print themselves (but I of course recommend using better ink than home printers use, most professional ink is more UV resistant).
If people wanted to upload their own custom designs, that would be cool too, but you might end up seeing your design being sold on some website if it's as easy as downloading and printing them.
1977 CB750
kaybee
« Reply #49 on: August 26, 2007, 04:43:01 PM »
Thanks for the heads up on Anubis. I bought a set from him bout a year ago on Ebay and got them with no probs, I was about to order another set from them until I read through this post.
 The website lists an all summer sale on "girlfriend preg, wife pissed"...I think I'll lay low on ordering for now.
 My FIRST choice though would be Carpy's guage faces, but dang, they are a little to pricey. (Cmon, have a summer sale too and knock off 10-15 buck.  ;D
